Main Forums => The Bass Zone => Topic started by: ilan on May 13, 2014, 10:31:40 AM
Introducing "Low Tension Flexible Flats" - .042, .056, .070, .100
Total Tension: 134.9lbs (61.19kg) - that's less than TI Flats!
http://www.labella.com/low-tension-flexible-flats-bass-strings/
(http://www.labella.com/wp-content/uploads/2014/04/Screen-Shot-2014-04-23-at-5.13.39-PM.png)
Steel vs Nickel pfffffft
Also the guaging is not my cup of tea - 118 won't work on older Gibsons, and I like to get the thickest that will fit the tuners (approx 105 like the TIs).
Low tension was never the selling point for me anyway (esp not on a shortie!).
That said I have been thinking of trying some other brands on some of my instruments, maybe even tapes.
The 118 is the B on the 5 string set. The E is 100, same as the long scale version of the TI flats.
My problem with TI flats is that they're mostly blurry mids and low mids, with not enough fundamental or high end. Or clarity. Can't say that I would like the LaBellas better but I might try them.
Edit: I see that bassstringsonline has the new LaBellas (http://www.bassstringsonline.com/La-Bella-Low-Tension-Flexible-Flat-Series-4-String-Flatwound-Set_p_2169.html) for $45 US vs $79 for the TIs.
TI shorties are 105 (or 104).
5 string set or no, you can use them for whichever string you want (though you're right; I didn't notice that). Had a bud who did that - tossed the actual G string.
My favorite Labella Deep Talkin' Flats are the 760FL set which run .043-.060-.082-.104, so these are very close to the same gauges, and might feel pretty darn good. I may give them a run when I'm ready for a set. The only string where there's a lot of size difference is the A; it's .070 in the low tension set and .082 in the 760FL set.
My experience with TI's is that they start to sound good only when they are well broken in...
+1
I have a P bass on which the TIs are 14 years old. The bass isn't that old, but the strings have lived on several of my basses over the years.
I'm also a fan of broken in strings...they always sound better after six months or so.
I'm still a TI fan, but something similar and cheaper sure would be nice!
Pilgrim, have you used TIs? Any comments on how they compare to the Deep Talkin Flats (been considering those despite steel vs nickel)? TI's on all my basses is getting old and I want a change at least on a few (still have a bit of a stockpile of those from back when we could get em pretty cheap - never paid more than $40 or so per set). I love Pyramids on my archtop 6 banger (much more so than the TI Bebops I tried before that - again with the midishness), but the bass version is a little too pricey to try out on a whim.
Also these are round core vs hex core Pilgrim. The whole idea of a flatwound string with a round core makes me nervous thinking that the outer wraps will have nothing to bite on to keep them from falling apart.
I've never used TIs - too rich for me, and I've always been very happy with Deep Talkin' Flats with an occasional side of D'Addario Chromes.
The very best prices I have found on Labellas have been through Imperial Guitar in New York and Bassstringsonline.com. The latter site is owned by an active member on TB and he has been excellent about customer service. I had one string break due to my own error - accidentally tried to put long scale on a short scale bass - and he replaced the entire set with the correct length and just asked me to mail back the others. I know that he sometimes replaces individual strings for customers.
There are other strings made with flat material on a round core, and I'm not aware of any systemic problems with them, so I'm not convinced that's something I need to be concerned about.
Imperial Guitar: http://www.imperialguitar.com/ Check this - the 760FL set is $28.55!
And these guys have also special-ordered Labella sets for me when I called and asked - still gave me a great price.
Bassstringsonline: http://www.bassstringsonline.com/
Note that the 760FL set is $34.95...still a really good price. At this site your money supports another bass player.
Juststrings.com is $35.81 for the 760FL set.
TI flats are round core too. Regular LaBella DTB flats also have round cores. Don't get hung up on the core shape. I've never seen any reports of either brand having problems with the core separating from the wraps, although it's possible if you shorten it beyond the silks. Only time I had it happen was with a set of D'addario Chromes, which are hex core.
I thought all the LaBella flats were hex core before these new strings came out ???
I tried round core DR flats that had rough looking windings and saw others with similar issues. The TIs also have the layer of silk thrown in between there. I don't think the new low tension La Bellas have that.
Regarding round core - only an issue at the ends when you trim. To reduce the risk, do not trim the extra length of string past the tuning post until after the strings have been stretched.
Even if they do unwrap a bit, they won't unwrap beyond the kink point on the tuning post so it's pretty much irrelevant (aesthetic issue). If they unwrap before stretching is complete, the normal slippage that occurs may allow the unwinding to proceed a bit further but also usually not really much to worry about. Only saw a string unwrap to a worrisome point on a bass that came to me for a setup and the owner had no idea how to properly mount strings.
I doubt LaBella uses a silk layer, but that has nothing to do with the bond between the core and windings. That's done by tiny crimps. I've used LaBella DTB flats on one bass for years, never a problem with separation, roughness or any other issue. LaBella does recommend against using DTB flats strung through-body because there are several flat windings and a sharp bend can cause them to break.
About 10 years ago I called LaBella with a specific question and wound up having a nice conversation with Bob Archigian, their longtime national sales manager. Among other things he told me that the DTB flats and rounds were round core and that the Hard Rockin' Steel rounds were hex core. No big deal to me either way.
That's interesting to know Dave thanks. Then the new La Bellas don't seem different at all from the DTBs except for the gauges
A few other potential major differences:
- tension.
- core wire guage.
- both are steel, but there are so many different alloys - we don't know they use the same one
I think I'll give them a try some day when I run out of TI sets.
I think they must be very different. The DTBs have small cores and lower than average tension on the neck for their sizes, but they're stiff feeling compared to most others. They're almost like steel tubes. They're almost the opposite of flexible.
Is $5 a year not cheap enough for you?
It's not so much the average, it's the immediate expense.
There's also the comparable value. I've never been interested in spending 3x as much to buy TI flats when Labella flats have made me happy. If they had been a similar price, I might have been more interested.
