Author Topic: CURRENT CATALDO  (Read 146913 times)
Re: CURRENT CATALDO
« Reply #690 on: November 06, 2018, 05:50:42 AM »
Done and gone to Hamburg.
Big string ferrules finally in the marketplace
Peaks filed into the saddles to improve intonation.
Muriatic acid fumed nickel and chrome.
Re: CURRENT CATALDO
« Reply #691 on: November 06, 2018, 06:47:30 AM »
Bet that is one fine sounding bass...
Re: CURRENT CATALDO
« Reply #692 on: November 06, 2018, 08:45:49 AM »
Nicely done, and unique as usual.
Re: CURRENT CATALDO
« Reply #693 on: November 06, 2018, 09:31:28 AM »
Wow that looks awesome.
Hmm... was this the inspiration? I remembered this, Watt's old '56 from back in the fIREHOSE days...
Re: CURRENT CATALDO
« Reply #694 on: November 06, 2018, 11:04:58 AM »
I'v probably seen that  bass, but no.  I've built a number of basses for Uli Salm, starting with JAEbirds, REVs, and the MAX prototype. This was the last build for him.
Slab body with gut cut, Jazz neck.
So this one is a progression from that. Uli owns a lot of second generation Precisions so he wanted a contoured body but with a J profile neck and TBird pups. The concept was the pups and refin were done in the late 60s and then it was well played.
That's an Allparts 'Tele' neck shaved and tapered to 1-1/2" at the nut. He was OK with either a TBird bridge or the two saddle.   I owned a 55 and thought the two saddle adequate so I did it that way.
Re: CURRENT CATALDO
« Reply #695 on: November 06, 2018, 01:20:06 PM »
Large coolness factor!
Re: CURRENT CATALDO
« Reply #696 on: November 06, 2018, 02:28:12 PM »
Very much +1
Re: CURRENT CATALDO
« Reply #697 on: November 06, 2018, 05:52:01 PM »
Two Thunderbuckers have got to sound better than any P/J combo.
Re: CURRENT CATALDO
« Reply #698 on: November 07, 2018, 03:10:43 AM »
ThunderBucker 63 in the neck. DiMarzio jazz under TB cover in bridge, Uli wanted more treble output.  Balance isn't perfect but there are a lot of tones available.
SwampFest '18...shaking down the REV102 Tenner
ThunderBuckers wouldn't quite cover the string spread.  So I went with Aguilar G3 40 series, 4 inches wide.
Re: CURRENT CATALDO
« Reply #699 on: November 07, 2018, 03:36:04 PM »
Now, my Don, all you need for the next photoshoot, is a crisp white shirt, a tux, and maybe, just maybe, a single red rose... ;)
Re: CURRENT CATALDO
« Reply #700 on: November 07, 2018, 04:54:16 PM »
I'd settle for a photographer. ;)
Re: CURRENT CATALDO
« Reply #701 on: November 07, 2018, 05:30:34 PM »
Re: CURRENT CATALDO
« Reply #702 on: November 09, 2018, 06:15:49 AM »
Next up, OXbird and  BigBottom wide 5.
Re: CURRENT CATALDO
« Reply #703 on: November 09, 2018, 01:02:44 PM »
Coool.  Photos like that always make me wonder... What do you do with the scrap after you cut a body?
Re: CURRENT CATALDO
« Reply #704 on: November 09, 2018, 04:28:14 PM »
Sometime I can use them but mostly they just pile up.  The poplar Oxbird uses two cutoffs for the lower body triangles and there's going to be a big piece from the top once I cut it out. It'g getting painted
The BigBottom II is one piece spalted Alder.  It smells like a cross between artichokes, wet grass clippings, and brown paper towel when I route it.  Really soft and light even though its a hair under 2 inches thick and about 10-15% larger than a precision body.
