Author Topic: CURRENT CATALDO  (Read 140490 times)
Re: CURRENT CATALDO
« Reply #660 on: July 27, 2018, 12:34:44 PM »
That's ingenious!  :toast:
I noticed the tailpiece hole pattern doesn't match the bridge saddle spacing? Is that why you decided to not use the last hole and put the two octave strings on the G in one hole together?
Re: CURRENT CATALDO
« Reply #661 on: July 27, 2018, 02:31:09 PM »
Thanks, it took me four years before the light went on as to how I could get the look and function I wanted.
Nice eye...yes, that's the prototype 12 tailpiece, I don't know what happened. I rerouted the neck pocket on a 4 string RNR to fit a wider 22 fret 12er neck.  The anchors and tailpiece holes were in the correct place for the new bridge and tailpiece.  But one 2mm hole I couldn't get right.  Fixed on the current bass and got the Tenner right on the first proto.
Those five string ThunderBuckers cover all 10 strings.  That was a pleasant surprise!
Re: CURRENT CATALDO
« Reply #662 on: August 02, 2018, 11:34:45 AM »
The business end wiith properly drilled string holes. ;D
One piece alder blank for the next Big Bottom Wide Fiver...don't they all look like this?
Amazing what a wipe with vitamin water will do!
Re: CURRENT CATALDO
« Reply #663 on: August 02, 2018, 11:39:45 PM »
Beautiful!
Re: CURRENT CATALDO
« Reply #664 on: August 03, 2018, 02:50:57 AM »
Vitamin water??
Re: CURRENT CATALDO
« Reply #665 on: August 03, 2018, 03:12:14 AM »
Vitamin water??
Gwyneth was pushing it on QVC, I couldn't resist. Seriously, just plain water. Here's what he back looks like dry.
Customer wants a 'vintage tint' finish, it will probably be close to the look of the wet pic.
Re: CURRENT CATALDO
« Reply #666 on: August 03, 2018, 09:45:25 AM »
That looks really nice.
Re: CURRENT CATALDO
« Reply #667 on: August 25, 2018, 10:00:02 AM »
So, the Tenner is a go!  Got a victim customer to push it over the top and give the prototype a home.
Epi bolt on body:
Full speed ahead on the fin/refin.
Fill the 3 point holes with Durham's 'Rock Hard' Water Putty and recontour heel and lower horn.  Fill pg holes with plastic dowel
"Ebonize" Fretboard with Fiebing's leather dye and sharpie unnecessary dots.  Waiting on some black 1/4" replacement ones fom Les Ismore to complete the illusion.
Re: CURRENT CATALDO
« Reply #668 on: August 25, 2018, 10:13:43 AM »
I love the idea Carlo!  :toast:
But do think that bridge set needs some extra attention.
Re: CURRENT CATALDO
« Reply #669 on: August 25, 2018, 11:35:04 AM »
Thanks, Rob!
That's a prototype tailpiece made from aluminum stock.  Ditto the bridge channel. Customer has faith I'll clean it up, understands he's buying a prototype...this isn't his first Cataldo.  Both production parts are polished nickel silver.
Re: CURRENT CATALDO
« Reply #670 on: August 25, 2018, 01:21:03 PM »
Ah! That makes sense. Excellent! :toast:
Re: CURRENT CATALDO
« Reply #671 on: August 27, 2018, 10:02:34 AM »
Mixed up some Polaris White Nitro.  Basically Pure White with a bit of yellow and Burnt Sienna pigment.
Pure white undercoat on top of sanded spot primed mods.  Plenty of poly base on the untouched original finish. 61% humidity and 90F.  Better painting through chemistry.  Flash Off leveling solvent and No Blush retarder in 'slow'  lacquer thinner.
One coat Polaris white, Two coats clear nitro Piano Lacquer.  Done.
My '64 in the background, naturally yellowed after a Polaris White refin about 10 years ago.
Geezer Dots...because who isn't?
Re: CURRENT CATALDO
« Reply #672 on: August 27, 2018, 06:10:40 PM »
I really like the yellowed Polaris white on there.
Re: CURRENT CATALDO
« Reply #673 on: September 05, 2018, 10:36:32 AM »
Thanks, Rob!
Old school Candy Apple Red. Didspade pigments.
Samples done on white and black pickguard material and gray primer
Gray as the base it is, no pic.  trust me.
Gold base (flat gold pearl in acrylic lacquer
Bloodshot red and a smidgeon of blue candy color in clear lacquer
Two coats clear over the candy toner. Results 'off the gun'
Let the relicing commence (oh, the horror)...
Re: CURRENT CATALDO
« Reply #674 on: September 05, 2018, 11:13:39 AM »
Love it...! :mrgreen:
