Author Topic: BillyBo, my "summer" project  (Read 63590 times)
Re: BillyBo, my next winter project
« Reply #120 on: May 29, 2010, 06:52:22 PM »
Neck progress............
« Reply #121 on: May 30, 2010, 02:27:40 AM »
Don't have the setup or the practice to go that far into a build... I'll stick to my fin-work... ;)
« Reply #122 on: May 30, 2010, 03:46:53 AM »
Not a big deal really.  That's my $99 band saw and home made router table ($10 worth of plywood).
« Reply #123 on: May 30, 2010, 08:04:08 AM »
Very interesting!  I was wondering how you were going to do this.  So you dimensioned your fingerboard and applied the binding and used the binding as you guide for the beraing on the router bit?
So when you radius the FB does the binding clog the sand paper of the radius block?
Anyway, great work, as usual, and please keep the pics coming they are very helpful.
« Reply #124 on: May 30, 2010, 12:16:51 PM »
Yep.  I've built neck 5 different ways and I decided to do it this way once to see how it went.  So far, I'm happy with the process. Keeping the back, top and edges flat throughout most of the building process sure makes working with it easier.  Using the binding as an edge for the bearing was nice and easy.  I'm sure I'll have to clean my sand paper often when I radius the board, but I use 3M gold and it cleans very easily with a small wire brush.
The next thing I'll do is finish the headstock shaping and sanding, then the radius sanding and fret installation while the back of the neck is still flat.  Finally, I'll do the neck profile on the back and I think that's it!
Re: BillyBo, my "summer" project
« Reply #125 on: May 31, 2010, 01:15:15 PM »
Got the neck pocket routed today!  The neck pickup will cover the heel, so it won't show.  I have a lot of scraping to do on the body binding then I'll glue the neck on.
« Reply #126 on: May 31, 2010, 01:28:13 PM »
Anything in that Canada Dry, other than ginger...?  ;)
« Reply #127 on: May 31, 2010, 01:45:56 PM »
Looks beautiful Bill !
« Reply #128 on: May 31, 2010, 01:57:51 PM »
Nope, nothing exciting!   :toast:
« Reply #129 on: May 31, 2010, 01:58:19 PM »
Thanks Scott!  Happy Memorial Day to you and everyone!!!
« Reply #130 on: June 02, 2010, 04:32:30 AM »
Your work just gets better & better. Starting out with a refin to this.
« Reply #131 on: June 02, 2010, 04:49:34 AM »
Thanks!  Speaking of finishes, my wife has me just about talked into black!
« Reply #132 on: June 02, 2010, 10:14:29 AM »
Sparkly black...?
« Reply #133 on: June 02, 2010, 11:00:53 AM »
You should be able to pull off black Grasshopper!
Let us know if you do black how it goes.
« Reply #134 on: June 02, 2010, 11:29:00 AM »
Black Grasshopper...?
