Author Topic: Soldering volume pots  (Read 1596 times)
copacetic
« on: September 19, 2014, 10:56:26 AM »
Been doing some repairs on a few basses. Need to do some soldering work for connection pots etc. My local hardware said I should check the amount of degrees to make sure not too hot or enough heat to melt the solder... Any advice on the type or degrees for a soldering gun?
Re: Soldering volume pots
« Reply #1 on: September 19, 2014, 11:36:06 AM »
I know from experience that pots are hard to solder - specifically, the ground connection to the pot's case for shielding purposes.
That needs more heat than you need for most basic electronics work, and may need some flux too.
I suck at it. My only advice is get advice from someone who doesn't suck at it, and don't be like me :)
The lugs are easy though.
« Reply #2 on: September 19, 2014, 12:10:24 PM »
When soldering pots, the main thing is to be sure the pot is clean, no grease, oil, even oil form your fingers can mess us the adhesion.  I use a 100 watt iron and standard electronic instrument solder, the high quality stuff.  Can't recall the specs.  When heating up the spot I'm working on I keep the iron on the wire and apply the solder from the side.  Once I get a good bead built up, I turn the iron off and keep it on until I can see that the solder is cool enough it won't let go when I remove the iron.  Not necessarily the text book method, but it works for me.  I don't use flux on pots.
« Reply #3 on: September 19, 2014, 12:45:16 PM »
Also it helps if you scratch a bit the pot surface with a piece of sandpaper, but be careful to cover the scratched area completely with solder to avoid corrosion.
« Reply #4 on: September 19, 2014, 01:01:05 PM »
I use a Hakko soldering station:
Having variable temp handy is very nice.  Got this on Ebay a couple of years ago.
I agree about cleaning the surface of the pot.  The pot acts as a heat sink and you need enough heat to get it to soldering temp before you cook its internals.
« Reply #5 on: September 19, 2014, 03:32:31 PM »
My two cents worth is to make sure your iron is completely hot and to melt a bit of solder onto the tip before you touch it to anything.  This will help conduct the heat to your components.  That and keep your tip clean  ;)
« Reply #6 on: September 19, 2014, 03:46:32 PM »
I still have quite a bit of high-lead content solder down the shed that I use... mostly tend to use a quick-heat type or my gas-solder tool for smalls works that I use for work - up to temp pretty quick and has a protective cover that means I can but it straight back in the tool belt...
« Reply #7 on: September 20, 2014, 10:26:02 AM »
I have this image of a well-stocked tool belt.
Repeat after me:  "I'M BATMAN!"  :P
« Reply #8 on: September 20, 2014, 01:47:08 PM »
Sand the pot
Tin the wire
Get a small bead to stay on the pot
combine the two pieces
clip and wire tips extemding from the little pool of solder.
« Reply #9 on: September 20, 2014, 04:24:14 PM »
I love that iron... I've gotten a lot of mileage out of my Hakko 936.  Too bad they stopped making 'em
I usually run mine at around 725 deg for PC board work, and maybe 775-800 deg for soldering to potentiometer cans.
Kester 44 and I go wayyy back.  So nice to work with.  The RoHS directive is such a pain in the a$$ for musical instruments.  I get why the EU is so strict on this (what with today's mobile devices ending up in a landfill in 3-5 years)... but for restoration work and building music gear that is possibly dependent on defunct parts (ge diodes, old through hole components, etc) leaded is sometimes the only way to go.
I just recently switched to lead-free for new builds, but would still go back to leaded for restoration work or guitar mods.
« Reply #10 on: September 20, 2014, 08:44:00 PM »
I've never had to sand the back of the pot. Then again, it depends on your equipment.
« Reply #11 on: September 21, 2014, 11:36:31 AM »
Sanding is a common practice among plumbers before soldering copper.  The scratches and clean surface make a nice place for the solder to grab onto.  The real problem is grease and oil.  A clean pot is a happy pot when it comes to soldering.
« Reply #12 on: September 21, 2014, 01:28:48 PM »
Good pots donĀ“t need sanding. There are of course some cheap chinese ones that is tough to solder.
« Reply #13 on: September 21, 2014, 03:45:46 PM »
... made by Snickers... no nuts...
