Author Topic: Cool Rics on eBay / Reverb / Craigslist  (Read 348278 times)
Re: Cool Rics on eBay
« Reply #675 on: November 26, 2012, 03:21:09 PM »
If they would only stay blue!
Presume they are prone to fade...?
(and fretless too... 8))
« Reply #676 on: November 26, 2012, 08:12:38 PM »
Yes, it's only six years old and already green. The original color is a powder blue. It was first a custom color made for Jim Reeves and his Blue Boys. An image search will show you how green some of them have become.
« Reply #677 on: November 27, 2012, 04:09:22 PM »
My mums favourite singer, bar none...
I knew most of his material before I had picked up any instrument... ;)
« Reply #678 on: December 02, 2012, 10:55:05 PM »
S/8 in Red (reverse trim - chrome/white guard).
« Reply #679 on: December 03, 2012, 08:42:40 AM »
Just a friendly heads-up to anyone on the Internets looking at that red 4003s/8 serial C68789... that bass had a massive bow in the neck that the current seller didn't disclose.  Someone on Ebay bought it for $2770 on 10/25, and apparently has returned it (didn't look like a shill, and the seller left the buyer feedback).  Now the same seller states the neck is "warp free".
Fretting at the 20th left roughly 5/8" between the strings and fingerboard when I played it in October.  Even if they did manage to work the bow out, I'd be concerned about it recurring.  Prior to my experience with it, the bass had been thru Elderly, possibly Mike Parks (according to a post at RR), and now this place Gold Pawn (who I confirmed has a tech come in for setups).  If it is in fact problem-free, well then I'd expect it to hold a setup much better that that!
I could only speculate that this might be one of the specimens that requires truss rod swaps, or has a "soft timber" issue...  In either case, its probably fixable with some work - but buyer beware!
« Reply #680 on: December 03, 2012, 11:06:02 AM »
Thanks for clarifying that.
leftybass
« Reply #681 on: December 03, 2012, 02:47:36 PM »
Horseshoe's mounting plate looks backwards.
« Reply #682 on: December 04, 2012, 09:06:02 AM »
It is. If you flip a horseshoe trim ring around, the holes from the stock one match up, so you don't have to drill. Personally, I don't like the way it looks. I had put a horseshoe on my S/8 and the change in tone was so minor I decided it wasn't worth the extra weight, and having the shoes hanging over the strings. Back to stock (minus the cover).
« Reply #683 on: December 29, 2012, 03:30:38 AM »
A very nice 1972 S:
« Reply #684 on: January 03, 2013, 09:40:58 AM »
v63 in White! Like the very limited edition C64, but - thank God - without the upside-down headstock.
And the coolest serial number!
« Reply #685 on: January 03, 2013, 09:49:12 AM »
Beauty! And no doubt when it was made.  :)
« Reply #686 on: January 03, 2013, 10:21:51 AM »
That's sharp!  I don't care much for the reverse headstock on them either - always liked the v63.
Speaking of.... can anyone here recommend a place that can build a v63 pickguard that is fairly true to original (material-wise)?  Just curious if anyone has personal experience with the products from places like Pickguardian, and how they compare to original.
« Reply #687 on: January 04, 2013, 04:48:35 AM »
Tony's material is identical to RIC's Plexiglas (unlike Fender and pretty much the rest of the guitar world, that use vinyl).
His repro Ric guards are indistinguishable from Ric factory guards (which aren't always consistent, the white can be opaque or slightly see-thru, in which case you can spray the back side white if you want), except that he doesn't stick a strip of masking tape under the knob holes like RIC does.
SeanS
  • Jr. Member
« Reply #688 on: January 04, 2013, 10:02:17 AM »
Thing I could never understand was the guard was nowhere near right on these and the CS, it goes too near the edge of the body in the area of the Bridge Volume control.
« Reply #689 on: January 04, 2013, 10:24:14 AM »
I ended up with a (actually, very nice) 4003s8 project on the cheap, and may or may not want to fit a replacement pg.  Doubt I can (should) leverage the 1/2" neck pickup spacing while attempting to reinforce it, and so a v63 makeover probably isn't realistic...  (did get a horsey for it, though).  I should probably be thinking more along the lines of a 4000s8   ;)
At any rate, thanks!
