Author Topic: CURRENT CATALDO  (Read 138428 times)
Re: CURRENT CATALDO
« Reply #165 on: April 19, 2014, 08:13:56 AM »
under different circumstances i would by a cataldo bass just because they are the prettiest guitars i have ever seen. amazing every time!
Re: CURRENT CATALDO
« Reply #166 on: April 19, 2014, 08:45:25 AM »
Gets better every time!
Re: CURRENT CATALDO
« Reply #167 on: April 19, 2014, 08:59:35 AM »
Looks like a production environment!  ;)
Does the catalyzed primer self level or do you need to block it?
Re: CURRENT CATALDO
« Reply #168 on: April 19, 2014, 09:40:10 AM »
Yeah, as close as I'm going to get to a production line
It levels well. I block sand with 320 no-fil (white silicon carbide) paper.  Sands extremely easily, exactly like lacquer primer surfacer.  A 4"x5" quarter sheet will prep one body.  The main advantage is once it cures there's no further shrinkage, unlike lacquer sanding sealer.  Since it's made for automotive use it's ready to be top coated in hours, not days.
Initially I was concerned about using the right amount of hardener for a small amount of paint but now have it at 80 drops per 6 ounces of primer.  The instructions say "use one bottle per quart".  I started off marking lines on the bottle approximately quartering that (for 8 ounces).  As I realized I was wasting a lot of paint I started counting the drops.
The black body was done with the 80 drops for 6 ounces.  I put a LOT of primer on the body and still ended up with around a 1/2 ounce.  So the next one will be 5 ounces of primer and 65 drops.
Re: CURRENT CATALDO
« Reply #169 on: April 30, 2014, 12:14:14 AM »
Black and white and red all over.  I was lucky to get this paint run done before the summer monsoon arrived yesterday.
ExplorerBird ships Monday if the creek don't rise.
Re: CURRENT CATALDO
« Reply #170 on: April 30, 2014, 06:44:39 AM »
a russian newspaper!
Re: CURRENT CATALDO
« Reply #171 on: April 30, 2014, 02:30:25 PM »
Re: CURRENT CATALDO
« Reply #172 on: May 01, 2014, 04:02:26 AM »
like
Re: CURRENT CATALDO
« Reply #173 on: May 06, 2014, 02:24:07 PM »
My Sunday project was finishing my original MAX Special prototype in Inverness Green.  The newfangled acrylic lacquer requires shooting color and clearcoats in no more than a 24 hour period.  Came out pretty good.  I used it over the poly primer.  There are two dime sized holes that were plugged, one in the side and one in the back where I was messing around with recessed strap locks.  So far so good, no telegraphing.
Since I was shipping the ExplorerBird today I got a picture of the pointy and the curvy together.  Feista Red vs Inverness poly, Ford vs GM!
The Special is for sale.  Artec pickups with nickel covers, 21 fret reverse headstock Eden neck with geezer dots, quick release bridge, 9 lbs.  $795 with case shipped in the US.
Re: CURRENT CATALDO
« Reply #174 on: May 06, 2014, 04:19:56 PM »
That MAX Special sure looks nice in Inverness. I'm sure the Explorer is fine too but I'm not a fan of pointy or red items.
Re: CURRENT CATALDO
« Reply #175 on: May 06, 2014, 06:48:13 PM »
I'll say!
Re: CURRENT CATALDO
« Reply #176 on: May 06, 2014, 07:02:59 PM »
I'm really liking the reverse version of your headstock - especially as it relates to your truss rod cover.  I love the green as well I really like that color of red but, like Dave, I'm just not a fan of pointy stuff.
Re: CURRENT CATALDO
« Reply #177 on: May 07, 2014, 07:47:18 AM »
Thanks,I'm digging it too, came out better than I thought it would.  Especially since that version of the headstock is a little different from the current one.  That trussrod cover is a laser copy on plain paper.  I'll use it as the template for the plastic one.
Did a neck adjustment, very happy with the Eden trussrod after 2 plus years on the job.  Leveled the frets and got the action down to <3/32" E string at the 12th fret.
Re: CURRENT CATALDO
« Reply #178 on: May 07, 2014, 09:44:01 AM »
That color is going to look so good on my NR!
Re: CURRENT CATALDO
« Reply #179 on: May 07, 2014, 10:20:54 AM »
 $795 how could anyone go wrong?
