I hesitate to post this. $45 Thunderbird pickups.
Started by godofthunder, December 07, 2015, 02:51:11 PM
Quote from: Pekka on April 05, 2016, 02:54:55 AM
That was a good description if you ask me! Thanks!
I'm planning to replace the original pickups in my '76 with these. Do I need rings or can I use the originals?
Also, as I have to change the wiring, what pots? 500 or 250 kOhms?
The China buckers come with rings and screws.  I use 500 Pham in the vol and 300 or 250 on the tone.  300 ohms are hard to find and cost double the 250.  I can't say I can hear a difference.
Pekka
I ordered them without rings, there's an option at their site. Thanks for the potentiometer info, 500 and 250 it is then.
I used my Hagstrom 8 string last night at rehearsal, and under gainy settings the pickups were pretty prone to squealing. I've noticed they are also pretty microphonic, but they sound so good I don't want to pot them!
clankenstein
if the squealing stops when you put your finger on the pickup cover then gaffer tape on the inside of the cover may work.
Louder bass!.
veebass
I think I wrote here earlier that the bridge pup (nominal 9.2K) needed to be raised quite high to get a reasonable balance with a nominal 9.2K neck pickup. The pickup heights I settled with were- neck 8 mm below bottom of E string and bridge 10mm. Sounds great to me- just exactly what I was looking for.
The problem with this is the bridge pickup is almost out of the body and is a little unsupported, even with the chromed ring fitted. You can see the issue in this pic.
This worried me because the external wiring of the pickups is a little flimsy IMO (I had one arrive DOA because the external wiring was broken) and I didn't want to risk damaging the wiring by knocking the pickup sideways while playing it.
So I ordered some spacers from Thunderbucker Ranch. http://www.thunderbuckerranch.com/
Worked a treat- put one under the ring for the neck pickup and two under the ring around the bridge pickup- bridge pickup now solid as a rock. The spacers are ever so slightly smaller than the rings- I am guessing they are designed to go with genuine rings or the reissues that Thunderbucker Ranch sells- but no big deal. Well worth considering, if you go with these pickups.
BTW- I played her today after I finished installing the spacers and she sounds so great. Very happy.
Bionic-Joe
OK...I bought 2 nickel pickups...they have been sitting in Customs for 6 days now....is this normal????
how high is the g string off of that pickup?
veebass
#263
Quote from: nofi on May 16, 2016, 01:26:36 PM
Neck pickup minimum 2mm, bridge 4mm. I must have been having a senior moment when I measured the distances for my post above.  :-[
You could lower the bridge pickup slightly and use a trimmer internally to calm the neck pickup down a bit?
veebass
Quote from: Alanko on May 17, 2016, 02:36:10 AM
Yes or use the spare 8.2K one I have, which actually reads 8.5K, in the neck position. I like the sound of higher resistance one I have in the neck at present and the strings don't hit the pickups as I play, so all good.
I found a (new old stock) black BTH-1 for a customer of mine. Installed a repro humbucker and a custom pickguard.
This weekend its off to Spain.
Would that be a Blackbird? Stealthbird? I've never seen an all-black T-bird before, but that thing looks killer!
Quote from: Basvarken on May 19, 2016, 12:44:10 PM
It's beautiful! Wow...
