Author Topic: Blueprints/measurements of 20/20  (Read 22767 times)
  • Low Impedance LP's
Re: Blueprints/measurements of 20/20
« Reply #75 on: May 20, 2018, 06:56:28 AM »
I hadn't noticed this tread for a while. It sounds like you are really going to town on the 20/20 Reisue/Reissue! How close was the headstock thickness? That has got to be the oddest neck ever bolted to a bass. I guess that's what makes it unique.
tore00
  • Southern by grace of God
    • Snakebite
« Reply #76 on: September 21, 2019, 11:12:12 AM »
I've started working again on the 20/20 clone. After a long stop due to pain in my right arm, that I preserved to play, today I completed routing. I had no luck with pickguard, for some reason I cut always strange. Hope in the next days to assemble all the stuff and take some notes from it. Pictures to come soon
tore00
    • Snakebite
« Reply #77 on: September 28, 2019, 01:39:04 AM »
Yesterday I wired and had a nasty and strange surprise: everything was working fine but neck pickup was picking only G and D :o. Bridge one was ok. Both were measuring 55 K Ohm, but I know that there is a preamp and not wire only.
EMG HB is actually a split coil under a humbucker cover, but it looks that the coils are wired in parallel and one is dead
« Reply #78 on: September 29, 2019, 08:21:05 AM »
Lift a conductor and check each coil?
tore00
    • Snakebite
« Reply #79 on: September 29, 2019, 02:01:38 PM »
It looks sealed with some kind of epoxy resin. I will try hoping to see something
« Last Edit: September 29, 2019, 09:40:46 PM by tore00 »
« Reply #80 on: September 30, 2019, 12:01:34 PM »
I had one that was damaged (used purely for filling the hole in my RD where another damaged pup lived) sent from NZ and if I can remember it was potted with something solid...
« Reply #81 on: September 30, 2019, 09:45:12 PM »
It should be easy to tell the difference between wax and epoxy potting. If it's epoxy, forget trying to look at the innards.
