Author Topic: So I've ordered a Mike Lull JAXT4...  (Read 4630 times)
planetgaffnet
    • Nancy Johnson
Re: So I've ordered a Mike Lull JAXT4...
« Reply #15 on: June 23, 2015, 01:52:52 PM »
Here you go.  Side by side comparison.
I'm pretty pleased it has to be said, however there's a little issue on the bridge pickup that's (hopefully) being addressed today.  Pickup is noiseless until you play a note and there's a little crackling as the note decays.  My tech guy says it's probably a grounding issue or a dry solder joint.  He's sorted out far worse previously, so I trust his judgment.
Otherwise, it's great.  Balances nicely, pickups sound nice clean or effected.  The body is a bit bigger, but to me not significantly so.  I'm a big bloke, so it probably looks normal.  Heh.  I like the forearm bout chamfer...so used to the Gibson slab, so no more bruises.  The reverse headstock will take a bit of getting used to.  Stock set up had the action a tad high, so dropped the bridge a couple of mm both sides to get a bit of rattle.
Paul
« Last Edit: June 25, 2015, 01:48:53 PM by planetgaffnet »
« Reply #16 on: June 23, 2015, 03:19:59 PM »
The chamfer... that's why I modded my RD...
Nice... ;)
