Back into the details...finishing up the wiring harnesses I started.
Working on necks...installing inserts, adding serial numbers and cleaning up the polishing compound after the headstock finish:
Rounding the fret edges and "rolling the fretboard" slightly:
Something's missing, though:
Buttoning down the details...in addition to the swimming-pool rout, the area where the Switchcraft jack sits needs to be enlarged, and a small channel channel is sanded with a Dremel to accommodate the CTS pots and wiring, and pickguard screw holes are chamfered to prevent paint chipping:
All screw are stainless and the holes have a little beeswax added to make maintenance easier over time:
Models with pickguard-mounted pickups get connected to the ground:
The P'Nobird has its pickup mounted to the body, so it's connected at the same time as the bridge ground:
I think I'm gonna' need a bigger wall:
Lots to update this week.
I received a shipment of new Hipshot licensed machines...and they're now 100% shiny chrome:
I routed out and prepped the last two LSP bodies:
Enlarging the rout for a Switchcraft jack:
Brad, what's the nut width on the 32" conversion necks?  I need it with a tilt paddle headstock, maple/rosewood.  Thanks.
Quote from: dadagoboi on December 09, 2015, 04:48:28 PM
Carlo,
Here's a link to the current order form:
http://www.lowecustomguitars.com/wp-content/uploads/2015/07/LCG-Order-Form-MEDIUM-BASS-NECK.pdf
If you want holes drilled, it can be done, but the OEM needs very specific dimensions.
That can be written in the notes section.
Brad.
No problem, and thank you!
Quote from: dadagoboi on December 11, 2015, 05:11:14 AM
What's delivery time?
I'm saying 8 to 12 weeks.
The OEM has been pretty busy with NAMM work, but that may be quieting down.
I had both an 8-week and 10-week neck ship this week.
8)
Back to the builds:
Next, I Dremel a groove for the wiring harness to clear the large CTS pots, and then drill the string-through holes:
Here's how I ensure the ferrules holes drilled from the back line up with the string-through holes drilled from the front:
Ferrules hole drilled SLOWLY, then they are installed:
Necks getting strings and guides:
And a gallery shot:
CUSTOM USA Ridler BASS #1
CUSTOM USA Ridler BASS #2
CHIMERA Series LSP #3 - Sonic Blue
CHIMERA Series LSP Bass #4 - Seafoam Green
CHIMERA Series LSP Bass #5 - Antique White
