Babicz 3 Point Bridge FCH-3
Started by TBird1958, August 08, 2014, 10:49:07 AM
One of my subjects posted this in the Thunderbird thread on TB, I must say I find it far more appealing visually than a Hipshot - It's nice to see somebody make something that looks like it belongs on the bass.
Kudos Babicz!
Here's a pic in black just to appease Herr Gruppenfuhrer - thankfully it's available in CHROME too.
That is a VERY good looking bridge.  Quick string change, lots of adjustment, bridge lock-down once intonated.
Bionic-Joe
That is MUCH nicer looking than those Hipshot Masses of Metal
I'm told $30 more than Hipshot.
I think it's a great looking design - much more sympathetic to the bass, it looks good in CHROME on a shortie too  :)
Will there be a version for vintage Gibsons with two point bridges?
Interesting. I kinda liked the Babicz bridge on the new EB bass that I tested a few months ago.
I like the look of it. It looks less bulky than the Hipshot (which I like despite it's size) and less intrusive to the "flow" of the basses. Do I have another bass that needs a 3-point replaced??? No, but I can remedy that situation. All in the name of research you know  :mrgreen:
It looks great, and it can't be any worse than an original 3-pointer.
maxschrek
Quote from: 4stringer77 on August 08, 2014, 01:20:36 PM
I would be interested to know this, too. That's a very nice looking bridge!
...with nickel finish, please!
mc2NY
I can't see them making a version for the  60s two-point bridge.
There are thousands of three-point bridges....just a few hundred 60s ones.  No market to recoup R&D and manufacturing costs.
Never checked...Do the posts on a two-point line up to the two tail end posts on a three-point? I'm guessing no. But then you could use the same bridge on both.
The posts on the two-points are slightly offset vs. being straight across.  Hipshot makes (or planned to make) a two-point bridge with a set screw on one side that can be screwed in to accommodate the offset.
I can't really complain about the hipshot bridge for my 66' EB-3. It is made specifically for a two point bridge as you said Pilgrim and I believe it's a bit shorter lengthwise than the 3 point supertone. The posts are offset on my bass and the bridge is designed to work with either offset or straight posts. The Babicz looks much better on the Thunderbirds without hanging over the center block like a Hipshot would.
Quote from: Pilgrim on August 09, 2014, 10:17:25 AM
Indeed, used it on my LoZ EB0 project, and it works great. I really like that you can adjust the string spacing on them,
although it is a rather large piece of metal. But it is quite lightweight, adjusts the offset with a screw, and looks allright.
I must admit I like the old 2 point bar bridge best, but I´m not a three point kind of guy....
