CURRENT CATALDO
Started by dadagoboi, August 28, 2013, 08:06:57 AM
Art, my Don... nuf said... :mrgreen:
#751
Well, around here we call it Blart, but thanks, Ken!
I'm sending a PM concerning tech stuff regarding photography.
Uli Salm, my patron. six Cataldos among his five hundred plus bass collection.
40th anniversary celebration of 'Rudolf Rock & die Shocker' in Hamburg with two Cataldos, one on the shoulder and one in the rack.
Quote from: Basvarken on May 03, 2019, 07:42:16 AM
That's great Carlo!
Thanks, Rob
Quote from: slinkp on May 03, 2019, 06:12:17 PM
Five... HUNDRED???
He auctioned off about 150 two years ago on Heritage including a dozen or so '60s Reverses. I'm sure he kept the best ones. Before I built this we had a good back and forth as to what to do including pix of a bunch of his 55-56 P's.
Ended up doing a little more relicing than this pic but less than originally planned.
I'm finally moving on from shimmed neck pockets. Made a quick jig that rises .030 from the 15th fret to the 20th which gives about a .125 rise at the bridge on a 34" scale neck.
I worked with the blank of a 32" scale G8r I'm building and then decided to upgrade my MAX41 to a 21 fret set neck with tilt headstock and ebony fretboard.  Also going to do a raised center on it.
Harbor Freight $10 Wheel of Death makes a quick job of contouring.
One piece 1-1/2" poplar blank weighs 3.8 lbs.  About the same as basswood but harder.
Saturday Shop Snap
They just keep improving Carlo.
I custom mixed this from GM9792 waterbase/solvent basecoat with Kolorefx  'Silver Stunner' flake topped with Hi Performance Clear Acrylic Lacquer.  It's a combo of modern basecoat/clearcoat without the Isocyanate high or pot life of Urethane. It's actually 3 stage: Flat black/ Base Coat/Clear Coats.  The color coat required about five ounces of material.
It looks a lot better in this video:
https://imgur.com/dEYfkyM
Gets color sanded and buffed in about a week. The automotive acrylic lacquer is a durable but thin finish(compared to urethanes) with great transparency.  I'm gonna add 2 drops Mohawk Pano Lacquer per gallon and call it 'Nitro' :) Pretty much what everybody else does...
Quote from: dadagoboi on June 02, 2019, 10:42:25 AM
Quote from: Rob on May 22, 2019, 03:57:57 PM
Quote from: Dave W on June 02, 2019, 02:43:43 PM
That came out great.
Thanks, guys! Difficult painting last week with temps over 100 and humidity high. Heat index of 112 Tuesday.
That is one of the coolest finishes I've seen.  Fabulous!
