Author Topic: CURRENT CATALDO  (Read 135469 times)
Re: CURRENT CATALDO
« Reply #465 on: May 04, 2016, 10:43:59 AM »
Yeah, Tom!
I've never understood why the original TBird shape came to be called the 'Reverse'.  I try not to think about it these days.
From what I've read, it was because the "normal" orientation, as with a P-Bass, has a longer upper bout rather than the Rev's extended lower bout. I suppose it looked odd to them (whoever "them" is). That said, I agree that the reverse style IS "normal".
Re: CURRENT CATALDO
« Reply #466 on: May 05, 2016, 06:55:35 AM »
That was pretty much my theory. Must have been pretty rad in 1963.
Re: CURRENT CATALDO
« Reply #467 on: May 05, 2016, 08:40:43 AM »
Makes sense when you explain it like that. OTOH I don't recall anyone using either term back in the 60s.
Re: CURRENT CATALDO
« Reply #468 on: May 05, 2016, 02:40:12 PM »
They all look the same in the dark.
Re: CURRENT CATALDO
« Reply #469 on: May 05, 2016, 05:34:11 PM »
I don't either they were differentiated by year maybe but I didn't hear reverse etc until a lot later.
Re: CURRENT CATALDO
« Reply #470 on: May 05, 2016, 09:53:41 PM »
Another thing I recall is that the headstocks were considered "wrong" because they curled upward at the end, rather than down like the Fender 'stock. Even today, the pointy/droopy headstocks on miscellaneous and sundry "poser" instruments have a "reverse" variant.
Re: CURRENT CATALDO
« Reply #471 on: May 06, 2016, 03:26:20 AM »
Here's the poster for 'Poser'!
It will be a 32" scale neck through Twelver.
So is it a Reverse or Non Reverse? ;D
Re: CURRENT CATALDO
« Reply #472 on: May 06, 2016, 06:06:36 AM »
what a perfect name for it. ;D
Re: CURRENT CATALDO
« Reply #473 on: May 06, 2016, 08:50:03 AM »
It's a V3rZo!
Font, spelling, and typeface subject to change without notice.
Re: CURRENT CATALDO
« Reply #474 on: May 06, 2016, 03:01:36 PM »
Cataldo Dodici... 8)
Re: CURRENT CATALDO
« Reply #475 on: May 06, 2016, 03:19:18 PM »
Re: CURRENT CATALDO
« Reply #476 on: June 17, 2016, 03:20:46 PM »
Lefty is done and gone.  Plays great right handed with strap button on the neck heel.
H-22 time!
'67 needs a bridge carved, nut cut, selector switch rebuild, and de nicotining.  '63 needs neck touch up after I pulled the board and repaired the truss rod.
Re: CURRENT CATALDO
« Reply #477 on: June 17, 2016, 04:15:00 PM »
 :popcorn:
Re: CURRENT CATALDO
« Reply #478 on: July 27, 2016, 06:09:13 AM »
Twelver necks coming from Todd Mullins.  I've been following his work since he converted an Ibanez Destroyer neck into an 8 string.
Through necks, one 34, one 32.  3 piece maple, 12" radius ebony fretboards with 6105 frets, double truss rod.  Should arrive just in time for Fall building season!  I'll do the final carving.
Todd's a TB guy, posts a lot of interesting builds there.  Here's one:
www.talkbass.com/threads/thundertwins.927165/
Meanwhile, this MAX42 went out yesterday to Lakeville, MN.  8.2 lbs.  Trans jade on poplar, '63 Thunderbuckers, stacked pots.  I'm really happy with this one, probably time to quit!
Re: CURRENT CATALDO
« Reply #479 on: July 27, 2016, 07:32:09 AM »
I really like that last MAX.
