Author Topic: Deimel Firestar Bass  (Read 2426 times)
« on: July 31, 2013, 10:33:03 AM »
Has this been discussed here before? Lollar Thunderbird pups and by the sound the bass has in the demo some of you should be in ecstasy at their first listen. Throaty. Interesting how that piezo adds vintage distortion!
http://www.deimelguitarworks.de/home/firestar-bass/images/
http://www.deimelguitarworks.de/home/firestar-bass/premier-guitar-firestar-bass-demo/
http://www.deimelguitarworks.de/home/firestar-bass/vintage-rare-firestar-bass-demo/
« Last Edit: July 31, 2013, 10:40:56 AM by uwe »
Re: Deimel Firestar Bass
« Reply #1 on: July 31, 2013, 11:20:28 AM »
here...
[legal-eagle-mode] You have been somewhat pre-occupied of late so easy to miss things... [/legal-eagle-mode]  ;)
« Reply #2 on: August 01, 2013, 08:14:57 AM »
Alas!, memory a fickle thing is.  :mrgreen:
« Reply #3 on: August 01, 2013, 10:23:56 AM »
Familiar, that phrasing sounds.  I always suspected Uwe had a bit of this gent in his DNA.
« Reply #4 on: August 01, 2013, 02:55:39 PM »
It's the forehead... and the ears...  ;D
« Reply #5 on: August 03, 2013, 06:09:31 AM »
I'd like the looks better with a more Victory-esque pickguard and better knobs. Don't put 70's Fender amp knobs on an instrument. However, sonically, it appears this one tackles the the three big pickup bass format much better than the more Fender-looking Godin Shifter, but for the price difference, it had better.
« Reply #6 on: August 03, 2013, 07:04:23 AM »
Why not? Gibson did that all the time in the late sixties :)
planetgaffnet
    • Nancy Johnson
« Reply #7 on: August 03, 2013, 10:02:43 AM »
I just watched the Premier Guitar piece.  I like this bass a lot.
P
« Reply #8 on: August 03, 2013, 01:35:46 PM »
I like a lot about it ... but... upside down headstock... why why why?
« Reply #9 on: August 03, 2013, 01:38:01 PM »
for higher string tension on the E string perhaps?
planetgaffnet
    • Nancy Johnson
« Reply #10 on: August 03, 2013, 02:14:46 PM »
I read an interview with the bass player from Jimmy Eat World and he was going on about having left handed necks put on his custom shop P-basses...quick search laters:
Q: As far as your bass rig goes, do you use the same setup in the studio as you do live? I saw on a late night show that you used a Fender P-Bass with a reverse headstock on it. Do you use that one a lot?
A: That guitar came together, I guess it was a few years ago. I had it and the neck was broken on it, so I called up a friend at Fender, and he said, “Hey, you guys tune down a lot, right?”, which we do; we play a lot of the songs in C#, so he recommended that I try the reverse headstock. What that does is it makes the E-string have more length, and what that does is, it helps stabilize that really low note. Because before, and I had noticed this, when I’d hit the string and I was tuning, you can see the movement of the  string would add tension and change the pitch of the string.
...so it was (apparently) a tuning issue.  No idea whether there's any validity in this, you would also need to factor in string gauge...I mean would you tune a .100 or .95 to C#?
P
« Reply #11 on: August 03, 2013, 06:46:26 PM »
I don't know whether or not it would stabilize the note in that situation; it's certainly possible. There's a noticeable change in feel with a reverse headstock, although the actual tension doesn't change.
« Reply #12 on: August 04, 2013, 12:44:59 AM »
The brake angle behind the nut is more shallow on a reversed Fender headstock's bottom string compared to standard configuration, which means that tuner movement exerts less direct torque, making detuning easier.
« Reply #13 on: August 04, 2013, 09:09:25 AM »
peizo adds an interesting tone.   what is price point?
« Reply #14 on: August 04, 2013, 10:07:46 AM »
Prices are in the other deimel topic
