Hello all, I have a Warmoth body that needs a little touch up around the back of the neck pocket. It has three holes 2 @ 1/4" and 1 @ 5/16" where I doweled the original 3-hole pattern and I need to drop fill those. According to Warmoth they use urethane as a finish:
Urethane is our primary finishing material though we do use several thin coats of polyester as a base coat to fill the wood grain. The process is first to fill the grain, then the color coat is applied. Finally the top coats are laid down before final sanding and buffing. If the body is dyed, these colors are put on the raw wood prior to the base coat application. There seems to be much controversy about finishing materials and poly seems much maligned… Without sinking into the depths of this debate, let us just say that our finishes seldom exceed twelve thousandths on an inch in thickness. For the lacquer fans, there are others that spray this material though the cost is generally at least double for a very questionable sonic difference.
My question is this, since it is three small holes being repaired, can I use the clear polyurethane that is sold at Home Depot, Ace, etc?? Will there be any kind of bad reaction between the two clears? Is it basically the same material? If I can't use that, where is a good source for a urethane finish? I don't need much so I don't want to buy a large can of it if I can avoid it. Keep in mind that this is on the back of the body and could mostly be covered by a neck plate if needed so it doesn't need to look perfect. Thanks for any info/advice/help you can give.
