Author Topic: (No!) Problem Tune O Matic Bridge Les Paul Bass  (Read 8469 times)
Re: (No!) Problem Tune O Matic Bridge Les Paul Bass
« Reply #15 on: April 24, 2012, 04:11:20 PM »
Gibson is a God-fearing company. Attempting perfection is always tantamount to sacrilege and inherently doomed.  ;D
« Reply #16 on: April 24, 2012, 04:38:26 PM »
Easily fixed by drilling a stepped hole.
They probably drill those holes after the body is finished and the step would be bare wood.
They could just drill the holes perpendicular to the slope of the body, but then it would look like it didn't lay flat.
Anyway, it would be too much trouble for them to change their manufacturing procedure for the handful of basses they build.
gibran
« Reply #17 on: April 24, 2012, 05:24:30 PM »
Thanks to all. I greatly appreciate your feedback. I like my bass and I can live with it not being flush. Now I know it's a design flaw, not mine alone. It was better the bridge warwick on the penultimate model Les Paul. Anyway it sounds great!
Can someone (owner of the same bass) post a picture as my? Just to compare, and reassure myself...  Regards.
« Reply #18 on: April 24, 2012, 05:43:54 PM »
Too bad.  Did this ever happen on the old blob bridge, or the Evertilt?  I don't think so.
« Reply #19 on: April 24, 2012, 06:07:26 PM »
A doubting Thomas this Gibran is!!! Feel my wounds ...
« Reply #20 on: April 24, 2012, 06:28:59 PM »
I had it happen on a couple 3 point Epis, but not a Gibson.
  • Low Impedance LP's
« Reply #21 on: April 24, 2012, 06:48:16 PM »
Mine looks about the same as Uwe's. I can't help but wonder why they didn't countersink the hole a bit to get it down past the carved top radius...............
gibran
« Reply #22 on: April 25, 2012, 01:06:17 AM »
Very very fun!  ;D :thumbsup:
Thank you for your patience.   Now I Believe.... ;)
« Reply #23 on: April 25, 2012, 02:05:59 AM »
Mine were higher than Uwe's, I should have snapped a picture before I took it back.  They were also tilting toward the heel of the neck.   I think it's best to watch them closely and it you can detect movement, have it fixed.  As for countersinking, a junior designer could have thought of that.  Again, someone was asleep at the switch.........
A good preventative move would be using light tension TI strings.  Costly, but much less hassle than repairs.
Droombolus
  • Younger Old Fart
« Reply #24 on: April 25, 2012, 03:37:44 AM »
I had the "problem" with both on Epi's & Gibbie's .... I fixed my SG Bass some months ago, but they hold steady on both Supremes  8). On my last run of Epi's I had to fix 3 out of 4 ......
« Reply #25 on: April 25, 2012, 04:12:28 AM »
No doubt this could have been solved better from an esthetic viewpoint. You wouldn't catch a Yamaha, an Ibanez or a Warwick with that type of a makeshift solution.
« Reply #26 on: April 25, 2012, 04:34:32 AM »
Really how much extra would it of been to counter sink them?
One extra step when drilling the holes?
« Reply #27 on: April 25, 2012, 04:56:45 AM »
A counterbored (flat bottomed stepped) hole can be done in one step with a CNC machine or manually in two steps with a piloted bit.  A countersink makes an angled hole.
« Reply #28 on: April 25, 2012, 05:14:34 AM »
I don't understand why a countersink makes an angled hole?  That doesn't compute in my muddled brain.
« Reply #29 on: April 25, 2012, 05:33:23 AM »
countersink
counterbore with pilot, it drills a flat bottomed hole.
