Author Topic: Oh my, this is on its way!  (Read 11917 times)
leftybass
Re: Oh my, this is on its way!
« Reply #30 on: January 13, 2012, 10:26:31 AM »
I hadn't set-up the bass yet when I took that pic, had literally just finished assembling and stringing it. After set-up the bridge is much close to the pickup.
« Reply #31 on: January 13, 2012, 11:47:02 AM »
So how do Chromes sound on the bass? I have an old obscure set of dead roundwounds on mine. I might change to chromes... which did you use, short or long scale? Because I have a spare short scale set but there's the extra length from the tailpiece to the bridge.
leftybass
« Reply #32 on: January 13, 2012, 12:10:49 PM »
I need to replace the 5-pin jack before I know how it sounds plugged in.
The Chromes were out of my Used Strings Box, so I'm not real sure if they're short-scale or not, I just held them up to the bass and they fit so I slapped 'em on. Except for the E string the actual winding doesn't wrap around the post, just the silk portion.
« Reply #33 on: January 15, 2012, 01:57:59 PM »
You can always measure the string length past the bridge, but I'm confident that you need to add at least 2" to the scale length for strings that will fit.  That's common for basses with a floating bridge.
leftybass
« Reply #34 on: January 16, 2012, 08:00:22 AM »
Yep.
« Reply #35 on: January 16, 2012, 01:59:48 PM »
Im still wondering if a set of TV Jones Filtertrons would fit.  You might check that out if the stock pickups are stinkers.
« Reply #36 on: January 17, 2012, 09:17:50 AM »
I was thinking about getting one of these to use with the stock pickups.
Freuds_Cat
« Reply #37 on: January 17, 2012, 04:20:34 PM »
Do not think that this is a copy of the very gibsonovskoy model. No, ....
That whole ...erm...translation (probably too strog a word to use after reading it  ;D ) is pure comedy gold.
Digresion our specialty!
leftybass
« Reply #38 on: January 18, 2012, 08:08:19 AM »
Got a new output jack yesterday, so I'll get to actually hear this bass soon, maybe tonight.
« Reply #39 on: January 18, 2012, 09:15:07 AM »
We're all in suspenders over this....    ;)
« Reply #40 on: January 18, 2012, 12:16:18 PM »
Short scale chromes don't fit. The silk goes over the nut almost to the first fret.
« Reply #41 on: January 18, 2012, 04:34:34 PM »
That's as expected.  You need at least medium scale strings.
leftybass
« Reply #42 on: January 19, 2012, 07:30:43 AM »
Installed the jack yesterday, as mentioned, pickup output is low but certainly useable. Neck pickup volume pot seems to be the only one that works. No signal from the bridge pickup, and tone control has zero affect. Tone from the one working pickup is good tho', very old-school with the flatwounds. I dig it, and, I usually only use the neck pickup on two-pickup hollowbodies anyway.
New tailpiece on its way.
« Reply #43 on: January 19, 2012, 08:04:03 AM »
Another satisfied capitalist customer!  :)
« Reply #44 on: January 19, 2012, 09:52:16 AM »
Excellent. I recommend my mod - get rid of the bolshevik harness and install good quality pots.
