Anyone here have any experience with the Peavey Pro 500? I need to send out my Mark VIII head for repair...or cremation.
I can get it real cheap (it's like new) and I'm thinking about pairing it with my 210TVX and BW-115 (both are 4 Ohm cabs).
12AX7 preamp tube for warm tube sound
500 Watts @ 2 Ohms; 350 Watts @ 4 Ohms; 200 Watts @ 8 Ohms
front and rear 1/4" input jacks
-10 dB pad for active basses
tuner send jack for easy tuner hookup
input mute with blinking LED for silent tuning
contour control for tube-type EQ curve
active low and high shelving-type EQ
3-bands of versatileā full-parametric equalization
side chain effects loop with wet/dry control
foot switch capable input mute and effects loop
low Z electronically balanced line out with pre/post EQ switch
ground lift switch for line out
both SpeakonĀ® and 1/4" speaker jacks
preamp out/power amp in jacks
DDT speaker protection system with defeat switch
I also have a chance to get an Avatar B212 Neo (also like new) for it.
