Jack Hack
Started by PhilT, October 17, 2011, 06:19:50 AM
Freuds_Cat
another thread descends in to the bowels of the hypothetical back passage.  ;D
Digresion our specialty!
Yes, deplorably so. When actually there are more important things in life and, as a noted astronomer once said, man's quest should
really be Uranus surrounded by its ring of debris.
Quote from: uwe on October 20, 2011, 03:00:09 AM
That's what we call Klingons.............  ;)
It's a good reason to trim the hair around one's ................... ;)
Quote from: uwe on October 19, 2011, 02:56:09 AM
"I know you only have eyes for U Ewe ..."
The reason why the sheep are all nervous in Wales  ;)
... And quite right too, Herr Ken, ever heard of the ius primae noctis bestowed upon Global Moderators here?
:o :o :o  ... hold up... Phew...! I suddenly remembered that there are no moderators in the UK... ;D
... and just for a bit of balance...
That song is my ringtone. Most fitting for a lawyer me thinks.
ROFL from the disapproving look of some of your comrades... ;D
Mungi
To much OT here...  :bored:
To get back to the original question, if you are using the tone pot and want to get the most out of it, I would replace it with a VariTone. There are are number of those on the market. I got the HAS Varitone Plus. It is great because it also got a push/pull blend pot, but Stan has stopped making them. But there is also CertainBass Varitone, Big D Varitone, Stellartone Tonestyler (expensive!) and Villex Passive rotary tone booster, and of course you can also DIY if you are good with soldering (the link shows how to make the same as the HAS Varitone Plus with a push/pull blend pot).
I replaced the bridge on my Jackbass with a Hipshot Supertone. Don't know if it adds sustain, but it sure makes it easier to get the intonation right. I can't understand why Gibson/Epiphone insist on using those useless bridges.
How can you not get intonation right with a three point?  ??? I'm an intonation obsessive and I've never had issues other than if you adjust height, slant the bridge differently enough, you will have to reintonate again. But that is the nature of the beast. Before you complain, look at a Ric bridge!  :mrgreen: I've never had a case where a three point's range is not sufficient for pitch perfect intonation and I've set up hundreds of them with all kinds of strings.
Mungi
I did not say you cannot get the intonation right with a Gibson 3-point. I said it is easier to get it right with a Hipshot Supertone. Meaning I can get it right with a 3-point, but I can get it right easier and quicker with a Supertone. The 3-point is not good only because Rickenbacker got even worse bridges, and the Supertone is better than all of them.
Droombolus
Chances are you've got more sustain with the Supertone. It did wonders for my (ex-)Rivoli ......
Mungi
It is difficult to compare if you don't have two basses, but the Supertone did take care of the bridge screws coming out of the bass. And it helped to level, albeit did not cure, the neck dive.
The Supertone, of course, allows intonaton adjustment without action influence and vice versa. It
also did help with the sustain on my Blackbird. Not that TBirds have a sustain issue, but there was a small difference.
You couldn't pay me to put a Supertone on one of my 'Birds........Aesthics alone won't allow me!
Aside from that, once properly set up a three point doesn't require anything special in terms of maintainence - if anything it's a quite robust design (altho lacking in any sort of Teutonic cleverness) that takes my playing style very well.
ramone57
I've never tried a Supertone, but to echo Mark, I've never had any issues with any of the 3 point bridges on my basses.  the sustain factor is non-issue for me.  all of my basses, regardless of the bridge, have no problem with sustain.  I have a hard time imagining an electric bass that wouldn't have sufficient sustain.  or maybe I don't understand sustain.
Sustain is overrated.  ;D
