You referenced the EQ notch and I searched on it but could not find a reference post. Any direction you could give me would be much appreciated. I also was wondering whether there was a way to add a potentiometer to the inductor circuit so as to be able to attenuate the bass bleed at the lower frequencies. I posted a schematic elsewhere but got no comments as to whether or not the design was viable.
Final question: I see you have a recording bass in your photo - About a month ago I got a lead on a pristine 76 for next to nothing way up in Wyoming which I bought. It is heavier than a broken heart and much more treble than I thought it would be. What is your opinion of it as a player?
I just use an equalizer to cut frequencies at ~30Hz, rolling off anything in the ultra-low bass range (low-shelf EQ). That was a little trick that someone else here had shared, and it made a huge difference in live sound of those basses. I've been using SVT cabs, and it seemed like the 10" drivers struggle a bit trying to reproduce all the heavy lows from the mudbucker. They seem to be able to render the more useful frequencies more effectively when the sub-lows are cut.
Take a peek at schematics for the L6-S, Howard Roberts, (and probably others) with regard to the variable inductor/capacitor filters. Similar to what they did there, you could use a pot to govern the amount of filtered tone on an EB. I've never experimented with that, and would enjoy hearing the results of it if you do!
That Triumph (recording) is probably my favorite short scale bass at this point. They are heavy! Mine's around 10.5 lbs, but the weight distribution (all in the body) makes it hang nice while standing and doesn't make the strap gouge into my shoulder. I can do a 4-hour gig with it and it doesn't bug me. Bought that bass from a fellow in Texas who got it new in 1973, played it in a band for two years... band broke up, and bass when into the closet. Its a real time capsule piece! (well, aside from a few dings I've managed to give it
![Smiley :)](https://bassoutpost.com/Smileys/default/smiley.gif)
). It can be trebly if you want it to be, but I've found that I can dial in everything from the EB-ish boom on up. There's a really gusty middle-ground that I love and that's how I usually leave it set.
![](http://i87.photobucket.com/albums/k125/0chromium0/forums/triumph/DSCF0014a-1.jpg)
![](http://i87.photobucket.com/albums/k125/0chromium0/forums/triumph/DSCF0016a-1.jpg)
