Epi PRO IV w/case $395 BIN
Started by dadagoboi, January 10, 2011, 06:50:00 AM
Then there is something wrong with the wiring of this particular Pro. Unplugged, no bass should drain the battery unless you don't play it for several years.
That is a small issue to fix though.
I wonder how one of those Pros would sound passive with TB Plus pups. The effect of equipping a standard Epi with TB Plus pups is already stark.
Quote from: uwe on January 12, 2011, 04:55:50 AM
EMG makes major point in their BTC literature that it DOES, in fact, drain the battery with no cable present and that it is part of its design.
Quote from: Psycho Bass Guy on January 12, 2011, 05:42:57 AM
To keep the caps healthy? ;D
If so, then the drain is minimal and it takes years. But now that you say it, yeah, my Lee Sklar Signature, which I seldom play, did get drained just sitting in its stand.
Quote from: uwe on January 12, 2011, 08:05:11 AM
EMG lists battery life for the BTC as 625 hours whether plugged or not. That works out to 26 days.
That can't be on mine. I have basses where the EMGs last years. Maybe they changed the recipe a while back?
  Yeah sure I could have snagged this.........................I took the $ and ordered one of Carlo's bases.
These Active EMG's have been in this bass since 1984. I have to change the battery once every 18 - 24 months
Quote from: godofthunder on January 12, 2011, 06:53:05 PM
Good move!
