Removing pickup cover on 4001: grounding question
Started by Denis, November 07, 2010, 11:40:18 AM
Just removed the pickup cover on the 4001 and discovered it's plastic! It's a new replacement that came with the new pickup to replace the nearly dead original.
Question is, where does that ground go now that the cover's off? Can I simply run the screw through the pickup ring and spring, grounding it there?
Daniel_J
Quote from: Denis on November 07, 2010, 11:40:18 AM
Yes.
Thanks, got it! Much easier to play with that cover off!
BTW, the pickup covers have been chromed plastic almost since they were introduced.
