Any wiring experts who can help me?
Started by drbassman, July 07, 2010, 07:27:34 AM
You could try this for the mudbucker:
Basically:
- Connect the yellow and purple wires together
- Connect the white and green wires, and ground them
- Use the red wire as your output
I couldn't see a green wire on the mudbucker - so I'm assuming it might be ground...  Also, I couldn't see the white wire very well, but I think its that one on the treble side of the neck coil.  See if that meters out around 30K.
Unfortunately, I can't see where the wires terminate inside the minibucker, but try this same config and see if you get a 6-8K reading.  Hopefully, they used the same color keying on the wires...
Oh- and I pity the foo' that coil taps the world's most tinny, brittle pickup!   ;D
Quote from: chromium on July 07, 2010, 08:14:51 PM
Me too, but combined with some mud may have some nice results! ;)
I should have taken this picture earlier.  Here it is from the side.  The green is grounded to the pup frame.
Ohm readings are:  Purple and Red = 14.8       White and Yellow = 15.5
I'll do some measurements on the mini later tonight.
The third of your first pictures shows the white wires connected to yellow/purple - they would originally have been shorted together and left beneath the coils...
From the colours showing on the other pup, I would presume you could do the same on both - so this time, as per Joe... ;)
The darker side of Kenny would advise to ensure you reverse phase for some SHOCK AND AWE output... :vader:
Quote from: drbassman on July 08, 2010, 06:28:16 AM
Cool- those pics show everything.  That diagram I posted above should work to revert the mud back to its original config.  I'd expect to see a reading around 30K after connecting the wires as described, and measuring across the red (output) and the green/white pair (ground).
Are you going to try to restore the Varitone/choke setup?
Thanks so much for your help guys,especially Joe!  I'll let you know how it works out!
Quote from: Lightyear on July 08, 2010, 04:27:12 PM
I might try to do a varitone set up.  I like the look of these..............
http://www.bigdguitars.com/varitone.html
Wow! Those have been reworked for sure ! must be so you can split coils. Kinda scary !
Quote from: godofthunder on July 09, 2010, 02:36:08 PM
Yeah, Dr. Frankenbass was into these babies.  I'll restore them to their former glory!
Quote from: drbassman on July 08, 2010, 07:49:01 PM
You know, you could build one of those for little money, components are about 6 euros (without the dialplate).
Following Joe's notes was easy - reversing an MB's phasing is >quite interesting - I'll post sounds (once I get past my current hiatus) on my PC posting...
