EB-3L
Started by drbassman, July 05, 2010, 09:19:29 PM
Egg Buttie... don't forget the brown sauce... an' a cup of tea, ta... ;D
Thanks, I really lost track there for a minute!  Tea time sounds inviting............ :toast:
OK, you guys asked for it, here are the first steps in the fret board inlays............
Draw a center line on the board first............
Then, I find the center on each inlay............opps, I shot the picture before I corrected the line on this one!!!   :P
I clamp or double-sided tape each inlay and trace it with a mechanical pencil......
Tada!!!!!!!!!!!!
This is one tedious process, but I haven't been able to shorten it in any way yet!
Here's my inlay routing setup.  I love the base with the Dremel, but I can never get enough light around the inlay hole to see clearly.  The biggest problem is the metal baseplate.  I use a foot pedal to start and stop the router so I can keep both hands firmly on it when I fire her up!
So, I got creative and made an acrylic base and now I can see everything with a simple 60w bulb!
I rout first with a 1/8" bit and then go to a 1/32" for the fine lines and corners.
Freuds_Cat
great pics Doc. These are things I take for granted. Its very interesting to see how its done properly.
Digresion our specialty!
i'm learning here!!! nice technique Doc.  :popcorn:
#142
Nice work Doc!
Do you just work to the pencil line or do you scribe/cut the line to cut the grain and route to the scribe line?
Hornisse
That is too cool!
Very Nice!  Like the rails and the dremel base.
Grizzly sells this kit which requires a separate template for each size inlay but it seems that once you made the required for one board you'd be able to do future ones very quickly- if it actually works.  I could imagine something like this being used in a production shop.
http://www.grizzly.com/products/Inlay-Kit-w-Carbide-Bit/H3133
Quote from: dadagoboi on July 30, 2010, 12:23:24 AM
Interesting idea, I'll have to look into that.  A template sure would make things easier!
Quote from: drbassman on July 30, 2010, 06:07:56 AM
It's not too difficult to bang together rectangular templates like this.  Then use a pattern router bit to do the actual template on the bottom piece and square off the corners by hand.  Pin nails usually work, screws not necessary.  This is a pup ring proto jig.
I see, good one.  I really do need some templates if I'm gonna do multiple necks on down the road!  Something to work on for sure!  I also plan on developing some sort of radius jig too this fall.
Quote from: drbassman on July 30, 2010, 08:15:45 AM
Look forward to seeing the radius jig.
Fascinating and enlightening...
Is that a blower tube...?
