32" build idea - am I freakin' nuts???
Started by Lightyear, July 04, 2010, 09:50:05 AM
I love the Waterstones and the 32" scale they offer - just not on the four strings.  I've lusted after a Ric 3000 forever but I think the 30" scale as too small for my oversize mitts.  So I have the wild hair about building a single pickup 32" scale project.  I'm thinking string through bridge so as to be able to use regular strings.  I'm considering a Ric style body - though at this point I'm open to anything.  I'll probably go bolt on but perhaps with an extended pocket.
So, am I nuts?  What will I gain or loose buy using this scale?  Obviously there has to be something wrong with it as it hardly exists outside multistring basses.  I'm open to any and all comments - questions about my sanity will be redundant as my family has questioned that for years ;)
after checking thier site, i come away with the impression one should check into them. a 32" scale build is a great idea.
I think it sounds like a fun project, regardless of scale length.  Doesn't matter to me whether it's 30, 32, 34 or 35, it's all cool!
I dig the mid-scale!  They're very comfortable to play (as with the short scales), but with more authority in the low register.  That low-E will ring out when you want it to!  I remember reading that Alembic/RT used 32" quite a bit due to the fact that it was a good compromise between short scale playability and long scale sound.
My Ibanez ST-980 and Alembic Distillate are both this scale:
Sounds like a fun project!  I've lusted for the 3000s too.
I've always wanted a 32" scale bass too.  I'd go for it!
I don't care for the 32" scale, to me it's a weak substitute for either a short or long scale. It's okay on the D and G, but you don't get the nice roundness of a short scale and the E and A just don't ring out like a long scale. Especially the E.
JMHO, YMMV.
Great, now I've slipped over the precipice! ;D  Thanks guys!
Anyone have any idea on the number of frets?  Chromium, what's the fret count on your two 32's?  I always want to default to 20 but wonder about 22 - 24 might get a little crowded.
I also am concerned with string spacing in regards to the pickups.  I love the neck on my Stingray at 1 5/8"  - maybe something between that and 1 1/2 inches?
Right now I'm thinking maple neck, rosewood board, and chambered mahogany or walnut with a maple cap.  Any thoughts?
I'm going to post a request for 3000 trace here with Ric group so I that I have a starting point.
Quote from: Dave W on July 04, 2010, 12:18:14 PM
JMHO, YMMV.
You think the E is as weak on a 32 as it is on a 30?
Do you think a brighter wood would help offset the characteristic?
I've never heard that before about the weak strings on a 32" scale.  Since it isn't only about string length, I would think wood characteristics, pickups, wiring, etc. would have some effect or be able to improve on that.  Then again, maybe not!
I wouldn't call it weak, it just doesn't come close to the sound of a 34" scale E. I don't think a brighter wood would help, it's just characteristic of the scale length.
The 33 1/4" Rickenbacker scale is the shortest I've heard where the E still has the 34" scale sound.
Dr. Aquafresh
I have a mystery Washburn headless bass that used to say "Force 42" it's the only 32" bass I have but it always sounds killer. And I treat this thing like a red headed step child too. I'm not sure it has ever had new strings on it, just cast offs from other 34" Fenders... that I don't have any more.
It is the only bass that doesn't lose notes with the Aguilar DB 750 amps at our practice space, I don't know why but these amps just do not like me.
A Ric shape would be way cool too, I have been thinking about one for a while now myself.
Bring on the Nubiles
Okay, better clarify my remarks. I didn't mean that the sound is weak or that the strings are weak, I mean I think it's a poor compromise between long and short scales. You get the (relative) disadvantages of both, not the strengths.
Sort of the same way I feel about ground roundwounds.
Quote from: Lightyear on July 04, 2010, 12:22:49 PM
My 32s are both 24 fret... and yeah its guitar territory up there.  Especially on the Alembic, which sports some big jumbo frets.
Quote from: drbassman on July 04, 2010, 12:41:39 PM
The sustain and lower register response on these maybe is aided by the fact that they both have big honkin' brass sustain blocks sunk into the body, one's neck-thru, and the other has a beefy bolt neck attachment w/machine screws and threaded inserts (not sure if that makes a difference?).  Both basses are largely maple and mahogany.
Here are some sounds I had made putzing around on the Alembic when I first got it.  Might help give you some idea of the 32" sound...
   (bass and solo parts)
   (bass part at 1:15 - actaullly the whole song is the Alembic fed into an old Korg synth, which is tracking the bass' pitch )
#14
Thanks Joe!  The Alembic sounds great!  Of course, it's an Alembic  ;)
I hate to keep pestering you for info but:  Can you tell me what the nut width is on both of your 32's?  And, most importantly, what is the string spacing at the bridge?  I want to think this through carefully and avoid as many pitfalls as possible.  Standard spacing seems to be .750 or 19mm and it looks like I can get .6xx or 18mm-ish with A hipshot A bridge.
In line with string spacing is pickup selection.  At this point I'm thinking a Pitbull, chrome, or perhaps a Fralin Bassbucker in the sweet spot.  Both are humbucker size and I want to make sure that the strings line up to the pickup.  With the Pitbull the string spacing is identical to a 51 P - I would like to make sure that I line up to the pole pieces.
As for the neck pocket I'm thinking six to seven bolts, with a shaped neck joint, with machined inserts in the neck ala Mr. Aquafresh
