Author Topic: what is it with that E string on EB3 and SG basses?  (Read 13000 times)
Re: what is it with that E string on EB3 and SG basses?
« Reply #45 on: April 29, 2010, 10:29:53 AM »
I know I mentioned this before, but I had that issue with short scale chromes 100 E string...have been using GHS's with a 95-96 E string, and not had any further problems.
« Last Edit: April 30, 2010, 07:57:31 AM by patman »
« Reply #46 on: April 29, 2010, 02:08:42 PM »
I would think you could get away with a larger gauge round than with a flat, since it's more flexible and generally easier to intonate anyway.
barend
« Reply #47 on: April 30, 2010, 01:15:43 AM »
...have been using GHS's with a 95-96 G string, and not had any further problems.
95 for a G, that seems impossible. That's a very thick A string or a very light E string gauge.
Think you mean 45?
« Reply #48 on: April 30, 2010, 02:30:07 AM »
Perhaps he tunes his E to a G?  :mrgreen:
Stjofön Big
« Reply #49 on: April 30, 2010, 07:29:00 AM »
Oh... bass string... I thought we were talking about the... low, very low, G-string. I didn't really give it any thought, as I'm in the 180-pounds class. When so, you need at least a 95 G-string. Sometimes 100-110, just to hold the... better parts together. Correct me if I'm wrong, please!!!
« Reply #50 on: April 30, 2010, 07:40:00 AM »
Regarding G strings worn by 95 and more kilo people, I second that flatwounds are more comfortable/gentle than roundwounds. Unless you do like it a little rough.
« Reply #51 on: April 30, 2010, 07:56:56 AM »
Meant "E"
« Reply #52 on: April 30, 2010, 08:40:46 AM »
That was a very short reply. I don't think he wanted to delve any deeper into the affiliated subjects.  8)
« Reply #53 on: April 30, 2010, 08:51:54 AM »
The big question is whether the low end is round and warm or big and booming.
« Reply #54 on: April 30, 2010, 09:05:37 AM »
So shorties sound best when strung with lighter gauge strings then?
« Reply #55 on: April 30, 2010, 09:48:36 AM »
Yes and no. Too little tension and your flabbing all over, too thick a gauge and you have ghost harmonics and awry intonation. Jack Bruce was known to play relatively thin strings on his EB-3 for all his bending antics and you can actually hear that. And most short scale sets tend to be between 95 and 105 (with 105s already a little rarer) - Rob circumvents lack of availability of short scale 110s by stringing his hobbits with long scale strings. I find most 110s on long scale basses uncomfortable and presence-deadening, but I haven't played them on a short scale yet.
It also depends on how you play. If anything beyond the 10th fret on the low E is largely irrelevant to you, you won't mind if a thick string is too stiff there. If you like to double what you play in the low register without much change of fretting fingers one octave higher, the same thing would be an issue.
Aussie Mark
« Reply #56 on: May 04, 2010, 04:12:10 PM »
I think I have that problem too, with my new to me SG Standard, which came with Chromes.  My SG Faded with Pyramid flats has no E string issues, and neither does my TI Flat wearing Rivoli.
The .100 E string on the SG Standard won't intonate at all - when my TU-2 says it's tuned to "E" it's not, and I have to tune it half way between Eb and E for it to sound even close to being intonated anywhere up to the 7th fret.
Will this issue be fixed if I switch to lower gauge strings like the TIs?
Cheers
Mark
« Reply #57 on: May 04, 2010, 09:19:39 PM »
The short scale TI Flats have a .106 E, I would dump those Chromes and get what's already worked for you.
Aussie Mark
« Reply #58 on: May 04, 2010, 10:19:25 PM »
Good point Dave, another set of Pyramids would be the easy way out.
Cheers
Mark
« Reply #59 on: May 04, 2010, 11:33:31 PM »
Tuning's another issue: My Korg always has issues with E strings of shortscales. Mostly I tune them by ear. Only the E that is.
