TB+ pickup rings
Started by exiledarchangel, April 01, 2010, 12:21:47 PM
I'm searching for a pair of (black) pickup rings, does anybody know if they are identical to 60s and 70s Tbird pickups?
Hmmmmmmmmmmmmmmm no such animal I am aware of.
shadowcastaz
Ditto!what ol man C said.M
Do the rings from F.O.T.N. fit the modern black pickups?
Quote from: Nokturnal on April 01, 2010, 08:17:28 PM
I just went to my parts box and checked. I originally sent a pickup ring from a 60's bird and one from a 70's bird to David, so I know they're great replicas. What I didn't know (because I'd never tried it) is that they won't work with modern black bird pickups (at least not the set I have). The newer pickups are slightly larger than either the 60's or 70's pickups. It looks like the discrepancy is down to the difference in thickness between the metal cover of the older pickups and the plastic cover of the newer ones. I'd still recommend checking with Dave and seeing if he's got some that will work.
If that's the difference, perhaps some light filing on the inner edge would work.
He wouldn't have this problem if he just gave in to the goodness of CHROME  ;)
shadowcastaz
yes
Quote from: OldManC on April 01, 2010, 08:00:40 PM
http://www.fretsonthenet.com
Try there. :)
I already contacted him but he is not sure if the vintage rings will fit the modern TB+ pups. Dimensions seem ok, but he asked about the corner radius.
I guess I'll scan a drawing and send it to him to be sure.
I've sprayed the one mark set over black, but I've also had to shape it, as the body on my T'bird differs from a Gibbie...
YOU PAINTED THAT LOVELY CHROME RING BLACK?!
That's it.......Send the Luftwaffe over!
... and the pups covered in sparkly gold stuff (on a second attempt - did you voodoo the chrome beneath to shed its covering...?)
Honest Ma'am... it does come off for inspection purposes... (ducking for cover, a sparkly gold one...  ;D)
err... would you believe it's on an undercover mission...? (running much faster...)
Err going offline now and hiding in the shed until its safe to come out (stop sniggering, V...!)
QuoteI already contacted him but he is not sure if the vintage rings will fit the modern TB+ pups. Dimensions seem ok, but he asked about the corner radius.
They won't fit, but I had them make me a pair that would. Maybe they still have the template on file?
