Author Topic: Ripper p/g question  (Read 1267 times)
Ripper p/g question
« on: February 05, 2010, 11:26:06 AM »
Were the early Ripper p/gs single ply? I found a guy who makes p/gs for the early pup models but since the early ones have a dial plate for the varitone switch I'm not sure a triple ply will work. Thoughts?
Thanks.
Re: Ripper p/g question
« Reply #1 on: February 05, 2010, 11:44:39 AM »
This is a non-issue as I learned by coincidence. I have a 73 Ripper, the really early one with the different, more massive shaped body. Its pg was made of that single ply "tortoise" material that looks mostly black and doesn't age well, it falls apart as it has mineral content and is verdigris-prone, mine was contaminated with it (pre-owner had let that bass rot for a decade in his damp cellar as he confided to me). A replacement was necessary so I sent the original pg to Jeanie's Pickguards as a template. It got lost in the mail, but the pg maker told me he already had a pg tracing of a much later Ripper (two generations from mine, i.e. different post-1974 new body AND with the  1976 change of adjustment screws for the pups outside AND not inside the pup), should he use that? I agreed out of desparation (and asked him to leave the adjustment screw holes around the pups away as my two generations older Ripper would not need them) and this is the result, my old 73 Ripper with a new four-ply, now unblack pg that looks lovely me thinks.
It fitted perfectly. Don't be confused by the controls, the luthier mistakenly put the varitone where a control knob should have been and vice versa. I liked the way it looked, so I left it, but I could be remedied anytime. He left the dial plate away "because it looked crap" on the new pg and I agreed, but it would have fitted on there even with the 4-ply. That old one-ply stuff wast thick (just not durable).
So to answer your question. Later Ripper pgs fit early Rippers, just watch out for those pup adjustment screwholes.
« Last Edit: February 05, 2010, 05:54:11 PM by uwe »
« Reply #2 on: February 05, 2010, 12:04:10 PM »
Excellent! Many thanks! Your Ripper looks great!
« Last Edit: February 06, 2010, 08:14:07 AM by Denis »
EvilLordJuju
  • Mud is its own reward
    • Fly Guitars
« Reply #3 on: February 06, 2010, 06:15:56 AM »
My early '75 wide body ripper guard is one-ply, of course, and 2mm thick, in case that is of any relevance to you
Jules
« Reply #4 on: February 06, 2010, 08:14:35 AM »
Thanks, Jules. The measurement is a big help.
shadowcastaz
« Reply #5 on: February 06, 2010, 11:05:27 AM »
So Denis, where are you at with this ol 'dog?
hollowbody
« Reply #6 on: February 06, 2010, 11:09:22 AM »
Did you find pickups for this?  I may be able to help you out.
« Reply #7 on: February 06, 2010, 02:12:00 PM »
I may be interested in Ripper pickups if Denis isn't.
« Reply #8 on: February 07, 2010, 05:37:14 AM »
Still trying to get the paint off the body.  :P Stuff is tough!
Shadowcastaz was kind enough to dig up some pups and electronics for me so hopefully they will check out okay. "Yay" for tiny electrical work!
