January brings the snow
Started by PhilT, January 04, 2010, 04:52:01 AM
Plus the hidden Epi secret: Fretboard access from the 15th fret onwards is much better than on the Gibbie Birds. You can actually do Glenn Hughes'ish stuff up there.
Glad you like it!
Definitely a green eye issue over here in snowy Surrey...
PhilT
15th fret? Is that somewhere up near the body?
A previous owner did the strap button relocation trick, but put it so hard up against the underside of the neck I can't find a strap that will go on it. Might try to live with the neck dive.
PhilT
Band rehearsal last night. Also took the MIJ P, which is all black, so a bit of yin/yan there. It's an interesting comparison, the P seems to create it's own space, whereas the Epi kind of flows around and under. It would be easy to think it wasn't cutting through, but it's there all right. I played The Chain on both and the Epi won that contest. Definitely like it better than the Gibson IV, which I no longer have. I think I'm allergic to mahogany.
