it is just getting to the point that when i play my shoulder hurts so bad that night i cannot sleep. i am keeping my epi, shich for all practical purposed is a bolt on gibby after all my mods and my little practice amp which i can carry and will continue to have fun.
i am gong to do the rod build with my younger brother. so i am not out to pasture yet! lol, just slowing down a bit.
here is the list:
1) A one piece LP Junior (think 59 EBO shaped) in Mahog. Story on this one is I bought it from a guitar builder that moved to Fla from Nashville. He knew a tech that made this supposedly at the Gibby factory. Doug (the seller/builder) gave me the guy’s name that made this but I have forgotten it. It is really nice wood and has a Gibby neck notch that is rather small and not too deep. I have a Mahog, Maple laminated neck I was going to use that could be set like a S.D.Curlee bass if a person so desired. The neck would be perfect for a short scale Curlee like bass. The body has been curing about 3-4 years now according to Doug.
2) Laminated Mahog/Maple neck blank. Rough shaped 5 piece laminations. Been glued and curing over two years now. The builder stopped building guitars while he goes to dental school. The Mahogany is figured beautifully in this blank. One extra piece big enough for the wings in matching Mahogany to make a 59 Gibby like small style peghead.
3) I have too many bass pups: a) a Dimarzio Model G, NOS/NIB with no trim ring, but takes a regular humbucker guitar ring. It is the early model with four wires so it can be coil tapped in phase or parallel. b) a New Dark Star DS2 (Gibby spacing or close anyways 2.03” total center to center measurement) never been soldered on I bought directly from Fred with a black chrome trim ring. c) a NOS 70’s Gibby bass bucker pup, complete with all mounting hardware, never been soldered on I bought from a guy closing his music shop. It didn’t come with a trim ring and has a black markered number on the back. Said he had a case of them and this was the only one he had left. I did get a trim ring for this that is honestly relic’d and broken in one place, but very nicely super glued (no glue blobs showing!) and is stable. This is not a Jeanne pickguard trim ring but a real injection molded Gibby one with part number on the back. No original trim screws.
4) A chrome set of Schaller tuners, look like Gotoh GB7’s (not Clover leafed), NOS/NIB, closed gear.
5) NOS black Grover mini bass tuners, closed gear. Think I have the box they came in.
6) Black Chrome Schaller bridge I got from Warmoth, NOS, never been screwed onto a body, but no box, complete with spacer. I have kept this wrapped in tissue so it would not get too banged up!
7) Two piece bridge complete with studs, chromed, a cheapy but heavy and fairly nice looking. Pics can be seen on my photobucket (I will give you the link and the guest password at the end of this so you can see all this stuff)
![Cool 8)](https://bassoutpost.com/Smileys/default/cool.gif)
NOS BadAss bridge (original type) still in vacuumed plastic wrap. Chrome with no notches (I took the cardboard backing off the package). Why I did that I have no idea!
9) Gibby SG,EBO type control cavity cover, used but nice, no major gouges, black original Gibby piece, no screws
10) Gibby brass control cavity shield, used but nice and not torn up.
11) Blank bone nut. New but aged a couple of years.
12) CTS 300 audio taper pots (2) new
13) CTS 250 pots linear taper (2) new
14) Ebony fretless board with Maple inset line markers. I screwed this up and gouged it, but it is oversized wide and long and can be used on a short scale with the trimming losing some of the gouges and the worm hole. (wear my glasses next time dummy!!!), flat not radiused so when it is radiused it will lose most of the gouges. Little over a quarter inch thick as is. It has 25 lines and will require some work but can be made into a nice fretless board.
15) Gibson hard shell case (brand spanking new, fits the 59 EBO/LP Junior Mahog body I was wanting to build like a glove) couple of small scratches on the back, NO gouges!
16) Extra cheap set of chrome Epiphone bass tuners off my Epi EBO, used but nice, no screws. I replaced them with new set of SGRI Grover tuners off a Gibby and have these left. I didn’t replace the ferrules so the ferrules are Gibby. They fit!
17) Somewhere in one of these boxes I have a set of string through bass body ferrules, new never used. Cannot remember if they are black or chrome but they are there!
18) Two small bags of stuff like old capacitors, new PIO caps, Black Cat, Sprague … enough to do a couple of basses. Ratings on these vary, but some are old Fender (NOS) caps, others are surplus Russian military caps. Probably 50 or so caps total. I am too lazy to count or list each value. A few orange drop caps.
19) One new never been used Varitone with selector plate and knob, 6 position from HAS Sound. Plate has numbers 1 through 5 on it, 6th position is unmarked and is a bypass position.
20) One custom SG body, Lacewood and Mahogany. Fitted but not final fitted to a NOS Gibby 34” scale neck from GreatDealz on wishbay. This is a beautiful body and the neck is fitted tightly but needs set (depth wise or thinner) into the body more to narrow and make the upper fret access better. I gave 200$ for this body alone and it is beautifully made.
21) One NOS Triumph Gibby neck, long peghead, laminated Maple to match with the Lacewood or use on another body. 34” scale.
22) One Ebony MOP inset pickguard. Has a small wood grain ouchy but can be shortened and look right or glued and sanded and used as is. Nice inlay! I was going to sand the backside flat and lay it in the Maho body for the 59 EBO project.
23) Ebony head plates or wood big enough to make some ebony pick guards or control plate covers, 2 pieces little less than a quarter inch thick, about 4” by 6 or 7” each piece.
24) Small piece of highly figured white Maple veneer. Enough to do a head plate Nice! Approx .040 thick.
25) Set of two matching set screw type Ebony knobs with brass inserts where they go onto the pot shaft. Nice! Fit ¼” shaft.
26) One chassis for a two power tube amp, with face plate, back plate, new never been soldered on, drilled for transformer mounts, holes for tube mounts, ready to start on, with schematic for a 50 watt head bassed on a 59 Bassman schemo with two different plans for the preamp section and the template layout for the turret board layout.
27) 50 watt power transformer, condition unknown but not leaking. Taken from an old 50 watt Heathkit tube amp. Not original to the Heathkit. Good wires. Spec sheet on this one. Wiring key on original decal on transformer.
28) Old output transformer value not known, taken from the same amp, not original Heathkit item. Not leaking but condition unknown. Good wires, no spec sheet. No decal just an unknown number silk screened on the OT. I would guess about a 30-40 watt OT.
29) One studio amp. 30 watt. It is in an old Vox Berkeley 2 (solid state) head case (think slant sided Beatle amp look a like!). The guts are a 30 watt Peavey classic that has had the reverb taken out. It takes four 6BQ5’s and three 12AX7’s. The tolex on the case needs re-glued and needs some new corners that are available from North Coast Music. There are no major tears in the tolex but it is coming unglued in spots. All the original top vents are there and unbroken and the original handle is intact. This amp sounds sweet but has been transported by my daughter and has been in storage a long time. I know it needs re-tubed and the bias reset. The grill cloth needs re-stretched and glued but it is not torn and has the original face plate on it. I gigged a bit through a P.A. and did some studio work with it, but it is more of a guitar amp rather than a bass amp. The tone is to die for and I got remarks about how cool it looks whenever I took it out. This has MOJO major and is the reason I never restored the appearance because it is so cool. I would have it checked out and re-tubed at my local amp guru before plugging it in. It still has the original Vox serial number in it.
30) Hand guard/rest repop stainless for a mid sixties EBO.
31) Hand guard/rest for a three point bridge, one in stainless one brass plated ready for chroming
32) Hand guard/rest for a steel guitar in chrome, maybe an original
Gibby item, unknown to me. I think it is chrome plated.
I will include links for pictures of all these things. The albums listed on the left of this link will show you what is available. Just pick the album you want to look at and feel free to browse.
http://s170.photobucket.com/albums/u275/cathousemouse/password is bassplayer
The price for the whole lot is one grand. 1000$ USD.
get together with others and i will keep a record in my inbox who gets hold of me. then maybe you can get together and do the deal. the amp is in storage away from here but i can get it. i have all the other parts here. the cost is not cheap nor is it expensive. but is obatianable with a little cooperation between you players for what you may want. i am in no hurry to list this on ebay.
bill
