Author Topic: Neodymium EB-0 Pickup.........  (Read 2613 times)
Re: Neodymium EB-0 Pickup.........
« Reply #1 on: February 19, 2024, 01:04:58 PM »
Looks like a (wide aperture) humbucker, not a sidewinder.
« Reply #2 on: February 19, 2024, 02:10:23 PM »
Never seen before.
Any sound clips anywhere?
« Reply #3 on: February 19, 2024, 02:19:18 PM »
On top, it looks like the Curtis Novak EB-BSx but AFAIK that one's alnico, not neo.
« Reply #4 on: February 19, 2024, 02:49:18 PM »
Neodymium is pretty strong! I destroyed a Mustang bass pickup by fitting neo rods in place of the original alnico rods. The neo rods pulled together, ruining the flatwork!
Putting stong magnets under the strings at the 24th fret location on a shortscale bass could be a recipe for wolftones and choking unless you are careful with the pickup height.
  • Low Impedance LP's
« Reply #6 on: February 20, 2024, 12:08:26 AM »
They have a website. https://www.916pickups.com/
No real info about the company.
MusicMan uses neo on its Stingray Special. Discussed here: https://blog.music-man.com/instruments/stingray-special-spotlight-neodymium-pickups/
« Reply #7 on: February 21, 2024, 07:52:41 AM »
The Stingray uses active NEO Pickups. Not enough info on the 916 website to tell if they are active or passive…..
« Reply #8 on: February 21, 2024, 08:16:45 AM »
Are the pickups themselves actually active, like EMGs? It sounds to me like they're running the pickup through an onboard 18V pre-amp. The 916 pickups only have two wires, and the description of the neo P says "no need for batteries".
« Reply #9 on: February 21, 2024, 08:47:06 AM »
I think the pickups themselves are passive as they appear to have three hookup wires. Judging by the post on this forum, the wires correspond with the start and end of the coils, plus a chassis ground, grounding the poles. No requirement for power to the pickup:https://forum.seymourduncan.com/forum/the-pickup-lounge/335857-ernie-ball-stingray-special-18v-neodymium-wiring-in-series-help-swap-smb-4d
« Reply #10 on: February 21, 2024, 01:52:32 PM »
Stingray pickups are passive. The Stingray Special uses EB's newer 18v preamp.
No reason to think the 916 pickups are active. I can't think of anyone other than EMG currently making true active pickups.
« Reply #11 on: February 21, 2024, 04:07:35 PM »
« Reply #12 on: February 21, 2024, 08:30:51 PM »
Thanks, Brad. He explains a lot there.
« Reply #13 on: February 22, 2024, 07:36:31 AM »
Thanks! That did answer a lot of questions…..
« Reply #14 on: February 22, 2024, 07:38:22 AM »
Curious what tonal range his Thunderbird pickup hits.
