Author Topic: Oooweee it's an UV!  (Read 2136 times)
Re: Oooweee it's an UV!
« Reply #15 on: August 07, 2023, 02:08:41 AM »
Love it!
« Reply #16 on: August 08, 2023, 04:12:01 PM »
Absolutely beautiful! That should take pride of place in his collection. We need sound clips!
« Reply #17 on: August 09, 2023, 12:51:20 AM »
Of course I made the traditional quick (grumpy faced) video demo. ;-)
« Reply #18 on: August 12, 2023, 12:51:29 PM »
What a GREAT sounding bass (we already knew how great it looks)! You're a true artist, my friend.
Ze UVee ...
« Reply #19 on: August 16, 2023, 03:12:15 PM »
Look what this extremely talented Netherluthier made for me  ...
So far I've only played it "dry", i.e. unplugged, but:The fret job, the neck, the high register accessibility and the set-up are of a quality I have not encountered on any other bass yet - and I have a few.  And it looks and feels gorgeous.
Hey Holländer, post some pics how it came about!
Re: Ze UVee ...
« Reply #20 on: August 16, 2023, 03:19:45 PM »
pssst Uwe, we've already been discussing your bass here:
https://bassoutpost.com/index.php?topic=12410.0
Re: Ze UVee ...
« Reply #21 on: August 16, 2023, 03:42:34 PM »
turn it up
« Reply #22 on: August 16, 2023, 07:49:04 PM »
Oh, I didn't know it was here ...  :-X :mrgreen:
« Reply #23 on: August 16, 2023, 09:24:49 PM »
What is that song again you're playing? Led Zeppelin? Sounds familiar ...
« Reply #24 on: August 17, 2023, 12:34:36 AM »
Per request of Uwe I'll post pics of the entire build process here.
It's copy/paste from a thread in Talkbass where I've already shared this.
Had my wood supplier make me a nice ply neck blank of White Limba (akaKorina) and mahogany veneer strips in between
Plus two slabs White Limba for the body wings
A nice start for this project
Routed the trussrod slot. And cut out the part for the spokewheel
« Reply #25 on: August 17, 2023, 12:35:31 AM »
Sawed the headstock angle
Drilled holes for the position markers
Glued the postion markers in and sanded them flush to the radius of the fretboard
Hammered the frets in
Cut out the opening for the trussrod access
Made the trussrod cover to fit the access slot
Fretboard ready to be glued onto the neck
Checked the neck/body angle before I glued the fretboard on
Sawed the rough shape of the neck
Glued the fretboard onto the neck
« Reply #26 on: August 17, 2023, 12:36:45 AM »
Fretboard in place
Filled the little gaps under the frets with a mix of rosewood sawdust and wood glue
Glued the first body wing on
And then the other wing
Sawed the outline roughly (sorry no pic)
Then routed along the MDF template for the first outline
Second step was to route the outline for the recessed "armpit" of the V
Used the same template for the pickup cavities and the controls cavity
Then shaped the neck and heel
« Reply #27 on: August 17, 2023, 12:37:56 AM »
Drilled the bridge stud holes
And the holes for the string through body ferrules
Shaped the headstock and the volute
Starting to look like a bass
Put the ground wire in and hammered in the inserts for the bridge studs
Forgot to do the side position markers before I glued the body wings on. Luckily the wings are not very wide at the end of the fretboard, so I could drill holes there without a problem...
Made the side dots
Scored a nice water buffalo horn for the top nut
Cut the topnut
« Reply #28 on: August 17, 2023, 12:38:39 AM »
Made the control plate / pickguard
Made the faceplate for the headstock and glued it on
Drilled the tuner holes
After that the bass was ready for staining.
First did a layer of yellow (still think this would have been a great colour for the end result too)
Then did the reddish mahogany stain
And a darker layer
Stained the recessed bit in the "armpit" dark.
And sprayed a few coats of clear
« Last Edit: August 17, 2023, 12:59:04 AM by Basvarken »
« Reply #29 on: August 17, 2023, 12:39:18 AM »
More layers of clear
Put the decals in place
After lots of layers and lots of sanding in between she was ready for final sanding and polishing
Made the black spacers that go under the nickel pickup rings
And then mounted all the hardware
