Danke!!! Im in a pickle because the width of the neck is a bit narrow near the body. I know I have a Schaller 460 . I found the plate that goes in the bottom of the bridge that holds the ball end of the strings. I know I had 3 and sold 2. DAMN!!! I do have a NIB G3 bridge that may work . I also have a new hipshot. I might just make new saddles for the 3 point and do a string thru set up.
An aside, I always seem to set the neck too high off the body. I have to remove my Pontiac Gold bird neck(avatar) for the same reason. I should stop,remove the neck on the moderne and drop it deeper into the body. If i can find the bridge, Ill line things up again and see if i really have to reset the F@#**! neck.
Its snowing like a bastard here , BTW.
