Author Topic: Rex Brown Tbird?  (Read 4228 times)
Re: Rex Brown Tbird?
« Reply #15 on: June 28, 2022, 09:08:34 AM »
As long as the battery is full, an active bass is a safe bet in a live setting if you know neither the location where or the rig over which you will be playing. You can compensate for most deficiencies and also make a decent stand against a double bass drum.
This is my solution. It's attached to my strap.
« Reply #16 on: June 28, 2022, 09:15:53 AM »
My amp has a pre amp.
 :popcorn:
« Reply #17 on: June 28, 2022, 09:27:16 AM »
I've had a Sadowsky pre on my pedal board for over 15 years. I use it for a tiny bit of low and high boost. They're "boost only" BTW, no cut. Knobs turned all the way counterclockwise = flat. It's great for when I'm switching between passive and active basses.
« Reply #18 on: June 28, 2022, 09:30:30 AM »
I don't use a pedalboard, and when the Sadowsky is attached to the strap near the rear button I can adjust the knobs mid-song.
« Reply #19 on: June 28, 2022, 03:14:17 PM »
To this day, I've never used a preamp unless it was integrated in something. Not a dogma, it just never occurred to me.
I did bi-amping with two preamp rack components to a stereo power amp for a while in the 80ies and 90ies, if that counts, but never anything like the Sadowsky. I'm indiscriminate as regards amps - as long as it works and is loud enough, I don't care what rig I use (currently I use an Orange Little Terror and a Mark Bass combo side by side, since I have both in the rehearsal space, they might as well both run simultaneously when I play  ;D ). That "I only sound like myself over my own amp" I've always regarded as a guitarist whiney thing.
« Reply #20 on: June 29, 2022, 07:43:37 AM »
I've found that an Ampeg is as important to my sound as whatever bass I might be playing. It is what it is...
« Reply #21 on: June 29, 2022, 08:53:35 AM »
My requisite reply to every new Thunderbird that comes out: I assume there will be no left-handed version.
« Reply #22 on: June 29, 2022, 09:00:04 AM »
Yes, an Ampeg is the great equalizer, all bassists sound alike over it, very convenient.
Discuss!
PS: Essentially, my bass sound is what you hear when I play an electric bass unplugged (a mix of light touch pick playing with a thin, but stiff pick, forceful left hand fretting and right hand palm muting, just with more volume). A guitarist actually once cracked that as a joke to me: "Uwe, no matter what bass and no matter what amp and speakers, you always sound like your playing unplugged in your living room, just louder." I took that as a compliment then, but perhaps I was mistaken?  :-X
« Reply #23 on: June 29, 2022, 09:02:14 AM »
And that ain't right.
« Reply #24 on: June 29, 2022, 09:03:07 AM »
It's alright.
« Reply #25 on: June 29, 2022, 09:12:11 AM »
Yup, in the end that is all that's left.
« Reply #26 on: June 29, 2022, 09:13:03 AM »
The pickups, straight from the T-Rex's mouth: https://twitter.com/REJASFROMTEJAS/status/1541165498305351680
« Reply #27 on: June 29, 2022, 09:13:41 AM »
It's all pretty sinister.
« Reply #28 on: June 29, 2022, 09:22:55 AM »
True, the end is nigh.
« Reply #29 on: June 29, 2022, 09:31:02 AM »
