Author Topic: Time capsule 1969 Teisco Del Rei guitar-scale bass  (Read 1553 times)
Re: Time capsule 1969 Teisco Del Rei guitar-scale bass
« Reply #15 on: April 28, 2022, 08:23:11 AM »
"Sustain is overrated too."
You will burn thunderbirdless in hell for this.
Seriously, the older I get the more the middle- and high-register comparative sustainlessness of bolt-ons bugs me. I'm at this point playing a lot my Yamaha Billie Sheehan something. It's a wonderful bass in many aspects, but it doesn't sing in the higher registers. Not like a TBird or Ric does. Whenever I go up there, I go "Duh, where's the cello effect?"
I play a lot of melodies on bass, without a sustainy sound they don't fill as much, making my excursions sound thinner than they need to be.
« Last Edit: April 28, 2022, 08:32:30 AM by uwe »
« Reply #16 on: April 28, 2022, 08:26:27 AM »
In fact the family cat is one-eyed and mentally disturbed.
As for the bridge - I'd just unbolt it from the body and use it as a floating bridge, slant it as needed. Actually as I'm typing this I'm holding a Hofner 182 with its metal bar floating bridge and the intonation is near perfect up to the last fret.
Yes, surroundings and environment often reflect badly on pets.  :-X
"Slant it as needed" - good idea, I thought about reusing mine too, but the rollers guiding the strings are not really made for more than the slightest slant, strings bounce off.
« Last Edit: April 28, 2022, 08:32:56 AM by uwe »
« Reply #17 on: April 28, 2022, 08:44:17 AM »
Bridge adjustments are highly over rated . I’m a fan of the wooden popsicle stick bridge on Danos . There is a sweet spot for it , even with a two octave neck . It’s not exactly rocket science to find the spot . The Danos completely changed my views on just what it was that made an instrument good .
They sound better than the adjustable metal ones . More woody thump , less sustain . Sustain is over rated too .
(I will admit the modern bridges are much easier to set )
I had a Dano for a while and had no problem with the bridge.  I also have an EB-0 with the old (pseudo-adjustable) bar bridge and I like it a lot.
« Reply #18 on: April 28, 2022, 09:36:22 AM »
Never had such problem on my Gretsch 6070 with the Space Control bridge. It was slanted just as you'd expect.
(Unlike the bridge in the pic, mine had same-sized rollers and was therefore not radiused, just like the fretboard)
