Author Topic: T-Bird body thickness  (Read 2377 times)
    • Myspace page
« on: September 09, 2008, 12:58:39 PM »
How thick do you make your T-bird bodies? I think 1&3/4" is too damn thick, but would 1&1/2" be too thin? It would be for a bolt on neck, not a set neck if that makes a difference.
Thanks,
Andy
Re: T-Bird body thickness
« Reply #1 on: September 09, 2008, 01:25:35 PM »
I believe mine are about 1.25".  I'll check for you at home.
ramone57
« Reply #2 on: September 09, 2008, 03:37:17 PM »
1.25" is really thin!   my Ripper is 1.35" and I always thought they were thin bodied basses.
« Reply #3 on: September 09, 2008, 05:08:24 PM »
The inside width of the wings on my TB, next to the center piece is 1.25".  The wings at the edge of the lower and upper bouts is 1 1/16".  So, the wings are tapered from the inside out.  The center piece adds another layer and measures 1 7/16".  Does that help?
    • Myspace page
« Reply #4 on: September 09, 2008, 07:29:47 PM »
Yes it does. Thank you very much!!
« Reply #5 on: September 10, 2008, 03:54:55 AM »
 For my bolt on NR project I think I went 1 3/8
« Reply #6 on: September 10, 2008, 03:56:47 AM »
 I very much had in mind the Grabber-G3 neck pocket.
    • Myspace page
« Reply #7 on: September 10, 2008, 05:58:17 AM »
So 1 1/4 & 1 3/8 are safe then? I wonder just how thin a body can be before its too weak. I was hoping I could do at least 1 1/2 on mine. May go a little further than that now. Thanks for the help guys!
« Reply #8 on: September 10, 2008, 08:55:59 AM »
My all maple TB is 1 1/8".  The maple is solid and heavy, so I trimmed her down during construction.  Worked out fine.
ramone57
« Reply #9 on: September 10, 2008, 07:08:23 PM »
I've played a few birds but don't own one and I didn't realize just how thin they are.  I guess that's why they seem light, duh! :P
« Reply #10 on: September 10, 2008, 08:22:30 PM »
All Rick electrics are 1 1/4" and the standard Gibson SG body is 1 5/16" so I think you'll be okay with most woods. Just be sure to allow enough depth for the electronics and cavity cover.
    • Myspace page
« Reply #11 on: September 10, 2008, 10:07:31 PM »
Good point Dave. I think I'm going passive so I should be ok. May want to leave some room just in case I want to add some guts later.
