Suggestions for re-covering cab..
Started by Pilgrim, May 12, 2019, 08:49:48 AM
I got the cab yesterday and it's actually in much better visible shape than expected.  There is one place where the carpet material is rubbed through and it's loose, but I think I can glue it down and avoid the need to do a re-cover.
It's a 4-ohm cab and therefore is well suited for use with my 1967 Blackface Bassman.  I also found a dock for a Genz-Benz Shuttle which I can fasten on top of the Neo-X so that I can transport them as a single (heavy) unit, but the 4-ohm cab allows full power from the Shuttle head.
I have pix but my camera stored them in some obscure place that I can't find at the moment.  I'll try and find them and post them.
Loose is good you can either spray or roll the glue under there.
