Author Topic: 1967 EB-0 "restomod"  (Read 6546 times)
FrankieTbird
Re: 1967 EB-0 "restomod"
« Reply #15 on: April 20, 2019, 05:25:58 PM »
  Is it just me or did he remove a lot of material from the body unnecessarily?
Absolutely.  Just dowel the bridge holes and fill the pickup rout, done.
« Reply #16 on: April 20, 2019, 10:54:20 PM »
He did remove a lot. We don't know what the customer's budget was, though, and what they discussed. I'm guessing that the customer is okay with what he's doing.
As he pointed out, that often causes the outlines of the plugs to telegraph through the finish. Veneering eliminates that problem.
« Reply #17 on: April 20, 2019, 11:19:13 PM »
Here's a question. After plugging, veneering and refinishing, will the bass be more or less original than if he'd just replace the P pickup with a second mudbucker and leave the original worn finish?
« Reply #18 on: April 21, 2019, 02:30:50 AM »
In my opinion, it's no difference. I still say go for it, if you have a good Gibson bass that is allready tampered with, it's OK to make it your own dream bass. What someone else did to it in the past does not matter,  or what you do to it. But to have such a job done to it (like in the vid) will depend on your wallet size. I'd rather have a plug popping through the fin (and I do have a couple) than have someone veneer it.
« Reply #19 on: April 21, 2019, 09:22:53 AM »
:rimshot:
« Reply #20 on: April 21, 2019, 08:50:29 PM »
Less original. Wouldn't look good with the cracks showing, of course, and that's probably why the customer chose the way he did.
Re: mudbuckers, since he removed the Model One, is he planning to replace it with a period-correct mudbucker, or reinstall it? With all of the non-original body modifications, seems pointless to replace the Model One. We'll see.
« Reply #21 on: April 22, 2019, 09:32:05 PM »
Part 4 is up. All about pulling the frets. He should have sped up parts of it.
At one point, when he was having trouble with a fret, he said "geez Louise!" I never heard anyone say that until I first moved north of the Mason-Dixon line. So I did a little searching. Turns out he's located in Arvada, Colorado. Go figure.
« Reply #22 on: April 23, 2019, 03:23:45 PM »
We'uns here in Coloradio are noted fer our moderate speechifying.
« Reply #23 on: April 23, 2019, 09:08:29 PM »
He does have some tasty looking Tele-inspired guitars at reasonable prices in his Reverb shop.
« Reply #24 on: May 04, 2019, 03:18:22 PM »
I also think he removed way too much wood. By all means plug the additional routes and bridge holes. At that point route a shallow rectangle into the top of the body and then patch this section in (Dan Erlewine did similar to a Telecaster that has a big Bigsby route in the body, on Youtube). Hogging out all that wood to depth of the P pickup route seems like total overkill.
I would like to see a breakdown of costs before I buy the line that the owner was working to a budget, or whatever. This method requires more time hogging out the wood and more mahogany to perform the repair.
From all of this I get the feeling that people are more precious about the level of invasive work when restoring a Fender instrument. Gibson basses are more likely to see big, invasive repair work for fairly trivial jobs. The guys putting pre-CBS P basses back to 1962 specs try and preserve as much of the original bass as possible. This guy restoring a '67 EB-0 basically blew 1/4 of the original wood into the wind to save a bit of time and effort. I sense the playing field isn't level here.
« Reply #25 on: May 16, 2019, 11:07:32 PM »
Part 5 is just out.
« Reply #26 on: May 19, 2019, 04:06:54 PM »
Nice!
« Reply #27 on: May 20, 2019, 09:48:02 AM »
Nice work. But completely over the top if you ask me.
With less effort you could make an entire new body that was as good as the original. Without all the hassle that he's putting the poor thing through.
But hey, he loves what he's doing. That's what matters most I guess.
steveonbass
  • Jr. Member
« Reply #28 on: May 20, 2019, 11:16:21 AM »
I agree Rob.
I do enjoy when he says things like "...so you don't dick it up".
FrankieTbird
« Reply #29 on: May 20, 2019, 02:28:56 PM »
This guy seems to like to make a lot of extra work for himself.
