Author Topic: Strange EB-0 on Reverb  (Read 1736 times)
« on: August 02, 2018, 07:26:02 AM »
https://reverb.com/item/10931087-gibson-sg-bass-eb-ebo-project-luthier-1965-1966-1967-heritage-cherry
So this guy is up on Reverb. Looks like an EB-0 with two additional controls and a hole for a pickup selector switch. In the electronics cavity there appears to be a choke as well.
I'm guessing the wiring is modified as the insulation is many different colours. The ugly common ground blob doesn't look factory original either.
Did somebody spoon the best of an EB-3 into an EB-0?
Re: Strange EB-0 on Reverb
« Reply #1 on: August 02, 2018, 07:50:03 AM »
Someone has done ugly things to the fretboard and the headstock. If the body didn't look better than the neck does, I'd think that bass had been under water.
« Reply #2 on: August 02, 2018, 08:15:06 AM »
It looks like '10' is impressed into the end of the fretboard using stamps?
« Reply #3 on: August 02, 2018, 08:44:54 AM »
It does. I don't remember seeing that before on an EB-0.
It does look like water damage. May have been in a flood and never properly dried. I'd guess the fretboard looks worse b/c it was unfinished.
Restoring to anything like it was originally would cost far more than it would be worth. $750? Tell 'im 'e's dreamin'!
« Reply #4 on: August 02, 2018, 12:17:41 PM »
I probably like EB-0 & EB-3 basses better than most.  But I'd actually feel sorry for any sucker who paid anywhere near $750 for that.  Just the headstock itself looks like it has been through some kind of war.
« Reply #5 on: August 02, 2018, 02:32:41 PM »
If that neck is still straight and not warped, it would surprise me.
« Reply #6 on: August 03, 2018, 05:26:44 AM »
Has the guts of an EB-3 been transplanted into the bass, or is something else going on?
  • Low Impedance LP's
« Reply #7 on: August 03, 2018, 06:47:36 AM »
The truss rod nut has been screwed in upside down. That could bee a sign that the neck is out of whack & un-adjustable………….
« Reply #8 on: August 03, 2018, 10:30:21 AM »
Not exactly - that is not an original choke (could be a 60s one with the faraday shield removed - never looked inside one due to sealed; the later unsheilded ones looked different).  It's probably noisey as heck since it is not sheilded and not dual coil humbucking like later ones.
« Reply #9 on: August 04, 2018, 01:00:07 AM »
Might even just be a big paper cap. Nothing odd at all about this bass, just a tired EB-0 with added tone controls. A road worn cherry perhaps?
« Reply #10 on: August 04, 2018, 04:07:41 PM »
I am very puzzled. What is the point of adding a second set of pots and drilling for a (missing) switch when there's still just the one pickup?  There's no route for a second one.
« Reply #11 on: August 04, 2018, 05:45:15 PM »
Could have something to do with whatever that terminal is next to the empty hole, I can't figure it out.
clankenstein
  • Never Gutless!
« Reply #12 on: August 04, 2018, 06:26:26 PM »
Could almost be middle and bass controls from a Ripper circuit,but what it is is a MESS!
Louder bass!.
