Brooks Thread
Started by Basvarken, May 13, 2017, 01:29:23 PM
Oh, I didn't know it was here ...  :-X :mrgreen:
Per request of Uwe I'll post pics of the entire build process here.
It's copy/paste from a thread in Talkbass where I've already shared this.
Had my wood supplier make me a nice ply neck blank of White Limba (akaKorina) and mahogany veneer strips in between
Plus two slabs White Limba for the body wings
A nice start for this project
Routed the trussrod slot. And cut out the part for the spokewheel
Sawed the headstock angle
Drilled holes for the position markers
Glued the postion markers in and sanded them flush to the radius of the fretboard
Hammered the frets in
Cut out the opening for the trussrod access
Made the trussrod cover to fit the access slot
Fretboard ready to be glued onto the neck
Checked the neck/body angle before I glued the fretboard on
Sawed the rough shape of the neck
Glued the fretboard onto the neck
Fretboard in place
Filled the little gaps under the frets with a mix of rosewood sawdust and wood glue
Glued the first body wing on
And then the other wing
Sawed the outline roughly (sorry no pic)
Then routed along the MDF template for the first outline
Second step was to route the outline for the recessed "armpit" of the V
Used the same template for the pickup cavities and the controls cavity
Then shaped the neck and heel
Drilled the bridge stud holes
And the holes for the string through body ferrules
Shaped the headstock and the volute
Starting to look like a bass
Put the ground wire in and hammered in the inserts for the bridge studs
Forgot to do the side position markers before I glued the body wings on. Luckily the wings are not very wide at the end of the fretboard, so I could drill holes there without a problem...
Made the side dots
Scored a nice water buffalo horn for the top nut
Cut the topnut
Made the control plate / pickguard
Made the faceplate for the headstock and glued it on
Drilled the tuner holes
After that the bass was ready for staining.
First did a layer of yellow (still think this would have been a great colour for the end result too)
Then did the reddish mahogany stain
And a darker layer
Stained the recessed bit in the "armpit" dark.
And sprayed a few coats of clear
More layers of clear
Put the decals in place
After lots of layers and lots of sanding in between she was ready for final sanding and polishing
Made the black spacers that go under the nickel pickup rings
And then mounted all the hardware
This bass is quite large. A standard case won't fit.
The Warwick Rockcase for BC Rich The Beast fits.
I made a special insert for  the V body shape to keep it in place.
I'm citing Edith's - daughter of a locksmith - comment on your work, Holländer, "Der kann was!"
And she says hi too!
I love its length, short scale Flying Vs are really a crime. It looks extremely elegant and sleek, not so much just "large". And the winged body extends the center of gravity so far back, it balances perfectly! It's the way a proper Flying V should be done.
It's also much lighter than I expected, yet not too light to seem insubstantial.
Black plastik is fantastik
You mean I should play it like Dave Davies?
https://youtu.be/UUALoD2E70s
Or like "I need to take a leak real quick"-Michael Schenker and his legendary Flying Pee?
I hope you got free deodorant with that! :P
Now that you mention it, I did wonder about the talented netherluthier's case candy ...
https://www.songmile.com/de/product/sr-rob-14-roll-on-bottle/
