General aaaaarrrrrghhhhh...
Started by Pilgrim, September 05, 2016, 12:38:43 PM
Quote from: lowend1 on September 08, 2016, 01:03:59 PM
What does any of this have to do with WWII aircraft? >:(
I wouldnt be hugely surprised if the Mosquito didnt have caulk holding something in place
Quote from: wellREDman on September 09, 2016, 06:18:41 PM
That's better. Always one degree of separation around here.
Quote from: patman on September 09, 2016, 09:10:41 AM
Have used the bronze "Alex"...it is my favorite brand also...
Home Depot has a "Quad" brand, rated for exterior use.  Got some.  Might have the chance to use it tomorrow.
Quote from: Pilgrim on September 10, 2016, 11:25:09 AM
OSI Quad is what the siding, window and roofing contractors around here use. Make sure you have a decent caulking gun, Quad requires some force to get out of the tube. Some cheap caulking guns won't be up to the job.
Presume that stuff has good low-temp tolerance...
Quote from: Highlander on September 11, 2016, 12:20:25 AM
Yup, it might as well have a little Frosty the Snowman on the label.
Quote from: dadagoboi on September 06, 2016, 10:12:03 AM
Like a newborn child it happens every day...
Paint it, black.  Or maybe to match the roof above would be better.
+1
Quote from: Dave W on September 10, 2016, 03:16:21 PM
"......Make sure you have a decent caulking gun......."
If Pilgrim is anything like me he probably has a half dozen somewhere in his garage  :-[  Invariably when I need one I've properly stored mine and can't find them X months or years later so I buy yet another one.  I do have a couple of the commercial grade guns and Dave is right - when you have a lot to do or  really stiff caulk a good gun is worth it.
I think mine is up to it, as it's better than the basic models. Right now I'm delaying work by watching the Packers.
Quote from: Lightyear on September 11, 2016, 01:23:31 PM
I only have two and believe it or not, I know where both of them are! OTOH there must be dozens of spools of teflon plumbers tape around here  yet I can never find one when needed. And what happened to all my spark plug gappers and car fuses?
I have 40+ years' worth of tools accumulated but I'm the only one who can find most of them in the garage. But I used the caulking gun (it didn't seem harder than normal) and got all the white colored...including a few spots where I had laid my hand on the shingles and left white caulk marks. They're brown now and blend in perfectly..
I use all the garage, including the ceiling. In the third picture below, you can see a black car top carrier mounted in a rack next to the ceiling.  A perfect way to avoid using space where we need to walk and move things.
I recently added ceiling-hung led light fixtures in front and half-way back - I only have the front ones on in this pic. They really do light things up.
Thanks for the suggestion of the bronze caulk. It covered the white stuff perfectly!  I also used it to cover some white caulk residue on some shingles where I got careless with my touch...the bronze is a near-perfect color match for the earth tone shingles.
Mission accomplished, and it only took about 30 minutes.
