Author Topic: General aaaaarrrrrghhhhh...  (Read 4885 times)
« on: September 05, 2016, 11:38:43 AM »
Just kicking myself around the place...
Last weekend I spent a half-day installing backer rod and caulking around two dormers and a 30-foot stretch on the back side of the house where new roofing left a gap between the siding edge and new shingles. I carefully selected clear caulk for this---or was sure I had.
Today i went out to check AGAIN to see when it would turn clear.  Still white.
So i checked the empty tubes, and one of the four was clear. The others are all white.  Someone must have dropped a clear tube into the other box, and i read its label and grabbed four.
MY FAULT for not checking each tube individually.  MY FAULT for not seeing it while I was climbing up and down the ladder.
Now I have white goop visible in the gap and on the dark shingles nearly all the way around the damn house.  And it's just after noon as I post this, so even getting a picture was tough....one frustration leads to another.
I'm checking options including removing it and re-caulking.  If I don't do that, the best idea I have is painting it black.
Re: General aaaaarrrrrghhhhh...
« Reply #1 on: September 06, 2016, 07:32:45 AM »
Ugh, that sucks. A couple of years ago I bought a tube marked clear. It was the whitest "clear" I'd ever seen.  :-\
« Reply #2 on: September 06, 2016, 09:12:03 AM »
Like a newborn child it happens every day...
Paint it, black.  Or maybe to match the roof above would be better.
« Reply #3 on: September 06, 2016, 09:28:50 AM »
Who is going to climb onto the roof to check the color of the caulking?
Leave it. There are more important things in life to worry about.
« Reply #4 on: September 06, 2016, 09:35:14 AM »
You're right! but...
Unfortunately it kind of makes a thin white racing stripe down the side of the house.  I am now the proud owner of a can of flat black paint and a 1" brush with which to make it less obtrusive. Doing it right would be stripping off the caulk, but it's not worth the grief.  I'll go for camo.
« Reply #5 on: September 06, 2016, 04:15:46 PM »
Depending on the brand of caulk why don't you just pick up a couple of tubes of the gray, black or bronze color and just "schmear" a coat of the color stuff over the white?  I've never cared for the clear, non 100% silicone caulks, as they all tend to yellow or get cloudy pretty fast.
« Reply #6 on: September 06, 2016, 07:58:16 PM »
Hadn't thought of a concealing layer of colored caulk!  I would need a medium to dark brown, but I'll take a look around. That would be more durable than paint.
Thanks for the idea!
« Reply #7 on: September 07, 2016, 12:32:49 PM »
... as they all tend to yellow or get cloudy pretty fast...
+1 ... would need to be high-end and have UV proof properties... I'd have prob gone for roofers mastic... black gunk... you have my commiserations, but if you try the "paint-it-black" route the paint will have to be of a highly flexible nature or it will just flake off...
« Reply #8 on: September 07, 2016, 01:42:52 PM »
Silicone caulk isn't generally meant to be painted unless it says, "paintable" IIRC.  Or is it acrylic of some kind?
« Reply #9 on: September 07, 2016, 04:54:08 PM »
There's roofers sealant that is a butyl based product.  I use siliconized acrylic - the brand I like is Alex - both HD and Lowes carry it.  Pilgrim I think the bronze color is what you're after.  This stuff is paintable but I think it will last long enough unpainted to serve it's purpose.
« Reply #10 on: September 07, 2016, 09:12:03 PM »
I made sure not to use a silicone caulk in case of a problem like this, so that's OK.
I checked the bronze stuff today - it's nice and dark, and looks perfect.  Picked up 3 tubes and will use them.
Right now I'm on a short two-day vacation in Breckenridge, Colorado so no action on the caulk until this weekend.  I REALLY appreciate the idea to use the bronze caulk - I think that will work fine.
« Reply #11 on: September 08, 2016, 12:03:59 PM »
What does any of this have to do with WWII aircraft? >:(
« Last Edit: September 08, 2016, 03:05:42 PM by lowend1 »
« Reply #12 on: September 08, 2016, 01:32:51 PM »
Nothing, although I suspect Mark could do something clever with a tube of caulk if challenged...  :o
« Reply #13 on: September 09, 2016, 08:10:41 AM »
Have used the bronze "Alex"...it is my favorite brand also...
« Reply #14 on: September 09, 2016, 01:44:37 PM »
We used to use Dow Corning sealant on the nav lights on Concorde... not quite WWII but I'm sure someone can make a connection... :mrgreen:
