Here are the latest pics. The main coats are now being applied. Ron at HMR Guitars says that this process will take a long time, as he waits for each coat to completely dry and shrink before applying another coat. Each coat goes through a heating and cooling cycle. Also, Ron says that the clear coats are mixed with and applied with the color coats. That way, if there is a ding that needs to be filled, you don't have to apply separate color and clear coats, but just fill the ding with the same color/clear mixture. --Rikkimax
