The resistance reading is only a valid comparison point if you're comparing two pickups with the exaqct same construction, bobbin size, wire gauge and wire insulation thickness.
Even if all those factors were the same, all the higher reading would tell you for sure is that the output would be a little hotter. Not necessarily better sounding.
