Thunderbird pickup dilemma
Started by finlover, August 12, 2012, 10:25:31 AM
Quote from: HERBIE on January 02, 2013, 01:01:06 PM
Function over form... to me they look too... dainty...?
Well they are dainty compared to a '76 or earlier. However, aesthetically I find them far better looking than the very small stock ones (yes, I know why Gibson uses those!), I think they're almost required if you're chroming a 'Bird tho  ;)
You are, most certainly, the High Priestess of Chrome... ;)
Dainty is right. Daisy bass! Chrome fairies!!!
You ruinses it!!!!
Though, to do him full justice, Professor Hills would be most inadequately described as a "fat Hobbit", more a lanky Elf ...
Quote from: uwe on January 03, 2013, 06:09:57 AM
You ruinses it!!!!
I'm just not the completist that you are Herr Moderator, some of my basses are "stock" but if one "needs" something to make me happy with it, I'll probably go ahead and do it  ;)
Elven...? Mark Blanchett...? Cate Hills...?
vates
Quote from: TBird1958 on January 02, 2013, 10:30:16 AM
I've put them on two of my modern 'Birds - Wit the stock holes, if they are in line with each other they will touch, barely. It hasn't been a problem.
And on Mr Sixx.
I'm in need of clarification, so I'll use some necromancy skill and resurrect this thread.
What version of Ultralites should be used with modern T-Birds: the 3/8 diameter version or 1/2 inch diameter version? Thank you
vates
Mark, thank you for your answer with PM! 3/8" that is.
One more thing:
Did anyone actually try to install Gotoh Res-O-Lites (pre-CBS type) on a modern TBird headstock? Will they actually fit the smaller modern paddle? Thanks!
Quote from: vates on July 08, 2013, 08:55:31 AM
One more thing:
Something like this showed up on my FB page, I didn't check it too close but what ever it was - looked very good.
vates
I've found this statement:
http://www.talkbass.com/forum/f8/thunderbird-club-pt-5-a-923476/index22.html#post13612356
So they will fit the pre-modern TB headstocks. With newer 'birds there's only Ultralites way :)
Here..........These are new from Hipshot, designed to fit modern Thunderbirds.
I have another shot of the front but my photobucket is being douchie.......
vates
Are these somehow different to regular Hipshot HB6 3/8'' Ultralite Tuners? Is it a new product?
Yes, they're new - the clovers are small enough to pass each other in-line.
vates
Thanks! It's a fun to communicate on two forums simultaneously :)
Quote from: TBird1958 on July 08, 2013, 05:19:09 PM
Damn, couldn't find small clover ones when i crammed in 3 on each side of my eb-0 headstock for the eb-6 conversion...
I somehow got them in, with the top two just clearing the logo, but there was some woodwork involved.
