Thunderbird Bridge Studs and Inserts
Started by OldManC, December 22, 2020, 02:32:05 PM
I'm finally having my white Bicentennial Thunderbird done (to 60s spec) and found these in the case. I've been gathering parts for so long that I can't remember where these came from. In the meantime, I have 3 additional basses that might get the same treatment if this one ends up being successful. Do any of you fine gentlemen know if these are branded (and what they're called) or where I might be able to source more? I like that the insert spacing is smaller than the regular three point inserts. These would work well with the other two point bridges I have.
Thanks for that, Rob.
After discussing it with Scott, we decided I probably got mine from him. It's been so long I'd forgotten he can supply them with his Badbird bridges. I dropped the bass off at my guy today and will be anxiously awaiting its completion!
Before:
It's to 60ies TBird intonation what the Manhattan Project was to world peace!
Those look the right studs for a 60s Gibson - short bushing, no flange and very aggressive knurls.
The Philly one is obviously a modern repro (much smaller knurls, which is probably why the bushing is longer; still better than other modern ones I've seen with barely any knurl at all).
