Gear Discussion Forums => Bill's Shop: Projects, Mods & Repairs => Topic started by: ack1961 on April 22, 2014, 10:48:28 AM
Title: Klingspor: One Sanding Block to rule them all
Post by: ack1961 on April 22, 2014, 10:48:28 AM
This tool might be old news to some of you...
I've had a dilemma where some fretless necks that I've needed to re-finish have an unconventional 8 degree radius.
I was going to make my own 8 degree radius sanding block, but I found this neat little tool today:
(http://i814.photobucket.com/albums/zz62/ack1961/Music/20140422_122019.jpg) (http://s814.photobucket.com/user/ack1961/media/Music/20140422_122019.jpg.html)
(http://i814.photobucket.com/albums/zz62/ack1961/Music/20140422_121843.jpg) (http://s814.photobucket.com/user/ack1961/media/Music/20140422_121843.jpg.html)
You loosen the lock and the contoured surface relaxes and conforms to the fingerboard radius. Tighten the lock back up and it stays where you set it. The nice thing about it that you have one block for all different radii fingerboards.
I'm easily impressed by stuff like this.
Steve
Title: Re: Klingspor: One Sanding Block to rule them all
Post by: Pilgrim on April 22, 2014, 11:10:48 AM
NIIIIICE!!!
And it even has a name like something out of Star Trek!
Post by: Basvarken on April 22, 2014, 12:02:09 PM
It's nice . But I think it's not wide enough...? Or?
Post by: ack1961 on April 22, 2014, 12:09:15 PM
Quote from: Basvarken on April 22, 2014, 12:02:09 PM
It might make the job a bit quicker if were the full width of a fb, but it's a great size in that it fits the hand perfectly.
We'll see how many fbs I can destroy before I get the hang of it.
Post by: uwe on April 22, 2014, 12:30:10 PM
It's not size, Rob, it's technique and persistence.
Post by: Pilgrim on April 22, 2014, 01:40:28 PM
Quote from: uwe on April 22, 2014, 12:30:10 PM
You've obviously never directed porn movies.  A terrible gap in your professional experience.
Post by: TBird1958 on April 22, 2014, 01:51:49 PM
You're such a Teutonic tease!
Post by: Dave W on April 22, 2014, 02:16:44 PM
Since it's narrower than the fretboard, it looks like it will be very difficult to do an even job and keep your centerline, especially since almost all fretboards taper in width along their lengths. More power to you if you can.
Stew-Mac used to sell an adjustable radius block, it must not be made anymore. I have seen a homemade one made from a length of aluminum c-channel with turnbuckles installed between the two sides of the channel. You tighten them to form it into whatever radius you need.
Post by: Highlander on April 22, 2014, 02:30:23 PM
Mind you, the principle is worth further investigation...
Post by: uwe on April 22, 2014, 05:08:46 PM
Quote from: Pilgrim on April 22, 2014, 01:40:28 PM
To my erectile credit, my resumé is graced by working for two years as an anouncer and DJ in a peep show and adult movie center in the Frankfurt Red Light District. And I had all those porn movies on about a dozen small monitors before me during my 7 hour shift - six days a week. Let me tell you that the excitement wanes after about three shifts.  :mrgreen:
As regards that yellow sanding block, I think the idea is a good one and I could see it work with some patience and a steady hand (no porn movie connotations whatsoever!!!). Nothing speaks against offering a wider one though.
Post by: Basvarken on April 23, 2014, 02:22:40 AM
Quote from: Dave W on April 22, 2014, 02:16:44 PM
That's what I meant
Post by: Pilgrim on April 23, 2014, 07:32:08 AM
Quote from: uwe on April 22, 2014, 05:08:46 PM
Clearly, this is an excellent preparation for a career in law.  If nothing else, I'm sure it gives one perspective. (Pun intended.)  :o
Post by: drbassman on April 23, 2014, 11:46:55 AM
Cute, but I don't think it's wide enough for the job.  A simple wood block would be safer and more effective.
Post by: ack1961 on April 23, 2014, 12:05:41 PM
Quote from: drbassman on April 23, 2014, 11:46:55 AM
Can you explain, because I really don't understand?
If the radius of the fretboard doesn't change (in this case, it's a constant 8 degree radius), then why would it matter if the block isn't as wide as as the fretboard, just as long as I stay on plane while I sand?
Since the radius doesn't change, isn't it theoretically feasible that I can move the block anywhere along the width of the fretboard, sand lengthwise, and still maintain the 8 degree radius?
I also don't see how a simple wood block (which is flat) would be safer - I'd be way more worried about knocking down the radius in spots with a flat sander.
Again, I'm just trying to learn and better understand the trepidation before I begin.
Thanks
- Steve
Post by: Dave W on April 23, 2014, 01:12:13 PM
Quote from: ack1961 on April 23, 2014, 12:05:41 PM
Thanks
- Steve
A fretboard that tapers in width is like a cone. Picture this: suppose you center the sanding block by the nut and draw two parallel lines going to the body end of the board. Easy enough to sand that parallel to the board's centerline. But you will have a long, narrow triangle outside those lines on each side. Each of those sections would have to be sanded exactly parallel to the centerline of the board, not parallel to the sides of the fretboard. It's doable in theory, difficult in practice.
I agree that a flat block won't work. That's fine for fret leveling, maybe Bill was thinking of that.
Post by: ack1961 on April 23, 2014, 01:36:22 PM
Quote from: Dave W on April 23, 2014, 01:12:13 PM
Gotcha, thanks Dave. Your example makes sense, but here's where my confusion comes in:
Question: An 8 degree radius sanding block (one that overlaps both edges of the fingerboard) is a constant radius, not tapered.  Isn't the idea of a radiused sanding block to center the block on the centerline of the fingerboard and sand it down evenly?
Q Pt.2): Is it because the full-width sanding block can cover the entire fingerboard without moving off the centerline the trick to keeping the constant radius while the fingerboard width fans out?
Thanks for all the help here.
Post by: Dave W on April 23, 2014, 01:58:23 PM
Yes, that's the idea, but unless the board's width is constant, it's very difficult to sand it evenly when the sanding block is narrower than the board.
Q Pt.2): Yes, that's it exactly.
Post by: ack1961 on April 23, 2014, 03:45:04 PM
Quote from: Dave W on April 23, 2014, 01:58:23 PM
Thanks....appreciate the knowledge transfer.
Wanna buy a sanding block?
Post by: Highlander on April 23, 2014, 04:09:11 PM
Perfect for a mando...
Quote from: Pilgrim on April 23, 2014, 07:32:08 AM
Clearly, this is an excellent preparation for a career in law...
... As in screwing people ... ?  :vader: ;)
Post by: drbassman on April 23, 2014, 05:56:08 PM
I meant a radiused sanding block if you want to maintain the curve of te frets.  Flat blocks are for leveling as Dave said when you have a lot to take off.  Issue both types of blocks.
Post by: ack1961 on April 23, 2014, 08:16:33 PM
Yup...understood.
8 degree radius is apparently an anomaly in the fretboard world, I could not find a block anywhere.
I could make my own, but that would take years and cost thousands of lives.
Post by: drbassman on April 24, 2014, 06:14:09 AM
Quote from: ack1961 on April 23, 2014, 08:16:33 PM
Yup...understood.
I hear ya on that one!  Doing the radius would be a major pain.
Post by: dadagoboi on April 24, 2014, 06:37:30 AM
Buy a 7.25"R block (vintage Fender radius).  Wrap a sheet of 120 sandpaper or close to that around your 8" radius neck and secure it (grit up) at the heel end.  Recontour the block on the sandpaper wrapped neck to match the 8 inch radius.
I'd dust a very light coat of black spray paint on the block before you start sanding it to size. Then you'll know when the recontouring is correct.
I didn't make up this technique, it's a common way of getting a nonstandard radius from a standard block that's close to what you need.
Post by: drbassman on April 24, 2014, 07:31:07 AM
Quote from: dadagoboi on April 24, 2014, 06:37:30 AM
Great idea.  I wouldn't have thought of it.
Post by: ack1961 on April 24, 2014, 11:41:36 AM
That's awesome - thanks.
Post by: dadagoboi on April 24, 2014, 12:30:38 PM
Quote from: ack1961 on April 24, 2014, 11:41:36 AM
You're welcome.  May be something I read in one of Dan Erlewine's books.
