Gear Discussion Forums => Gibson Basses => Topic started by: ramone57 on January 15, 2014, 11:14:43 AM
Title: one off LP
Post by: ramone57 on January 15, 2014, 11:14:43 AM
I like it but not quite as much as a production Triumph
http://www.ebay.com/itm/1971-Gibson-Les-Paul-Bass-FRETLESS-unique-rare-one-of-a-kind/301068354146?_trksid=p2047675.m1850&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D11%26meid%3D4139125065440668953%26pid%3D100011%26prg%3D1005%26rk%3D2%26rkt%3D5%26sd%3D330582424573%26#ht_1040wt_922 (http://www.ebay.com/itm/1971-Gibson-Les-Paul-Bass-FRETLESS-unique-rare-one-of-a-kind/301068354146?_trksid=p2047675.m1850&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D11%26meid%3D4139125065440668953%26pid%3D100011%26prg%3D1005%26rk%3D2%26rkt%3D5%26sd%3D330582424573%26#ht_1040wt_922)
Title: Re: one off LP
Post by: Dave W on January 15, 2014, 11:21:33 AM
Interesting. Not a genuine Gibson, though.
Post by: Basvarken on January 15, 2014, 11:39:31 AM
I've seen it before.
To me it looks like it's modified. Although the seller says it's not, it just does not make sense that Gibson would have ever built this bass.
Were BadAss bridges even available in 1971? I don't think they were.
The naked fretboard doesn't like like Gibson did it too.
The headstock has bindings. The body has bindings. Why doesn't the fretboard have any?
It would have made much more sense if they had put binding round the fretboard like they did with all Triumh bass guitars.
The wooden pickguard doesn't make sense to me either. Why would they use this instead of the regular laminated plastic?
Why isn't there any typography on it? Why different (non Gibson) knobs?
Di Marzio Model ones were they available in 1971? Dunno.
This is an employee build at best.
But more likely the result of some over-enthousiastic handyman.
Maybe he put a veneer over the top to cover up the holes? When I look at the sides of the control cavity in this pic I think I see the line of the veneer. On the right where the plate meets the top of the body it is clearly visible
(http://i.ebayimg.com/00/s/Njc4WDEwMDA=/z/E9kAAOxyVaBS1GwX/$_57.JPG)
Post by: uwe on January 15, 2014, 12:02:47 PM
No way that thing is from a Gibson factory.
Post by: lowend1 on January 15, 2014, 12:12:14 PM
Those aren't Model Ones. The size / proportion is all wrong, and they don't have mounting screws in each corner. The M1 also doesn't have ears. At best they are Model Gs that have been painted.
Post by: gweimer on January 15, 2014, 12:14:10 PM
From the listing description:
"I've owned this bass since the late 80's, and the story I got when I bought it was that it was built by a Gibson factory employee as a personal, custom instrument."
Post by: Granny Gremlin on January 15, 2014, 12:18:21 PM
Def not factory - the control plate does not have the usual metal foil on the back (component side) that Gibson always used - this acts as partial shielding and a ground plate.  This might be a noisy bitch; stay away... also it's bloody yucky looking - especially the plate (wood grain on different wood grain has got to be a fashion no-no, like wearing leopard print pants with a zebra tee, or navy with black); damn shame - looks like it used to be a real (even if not fully completed) Triumph at some point - body construction with that sandwiched layer, correct (and not too common) 2-tone binding on the body, the headstock overlay and what could be stock/original tuners, add up to that much in the balance of probability.
Quote from: gweimer on January 15, 2014, 12:14:10 PM
Could be; but still not a production Gibson.  I'd be inclined to believe that due to the pups being (vertically) shorter than Triumph pups and there's no sign of backfilling in that clear finish.  Note however that there's no binding or block inlays on the fretless board.
Post by: ramone57 on January 15, 2014, 02:27:43 PM
Quote from: Basvarken on January 15, 2014, 11:39:31 AM
I've seen it before...
I couldn't remember if it was discussed earlier although the bit about the pickups seemed familiar
Post by: gweimer on January 15, 2014, 02:33:11 PM
So I'm speculating a Gibson employee took some scraps and made himself something on company time, and eventually cashed in on it.
Post by: Grog on January 15, 2014, 04:27:25 PM
I just read this earlier today on the Gibson Forum...............
http://forum.gibson.com/index.php?/topic/89439-idinfo-help-on-my-70s-les-paul-bass/
Post by: Highlander on January 15, 2014, 04:31:02 PM
I was thinking along the same lines as Gary...
Pups just look plain wrong...
Post by: doombass on January 15, 2014, 05:49:49 PM
My thoughts on this one are the same as Gary's and Kenny´s. Also, if this is an emplyee build he/she did clearly not intend to make nowhere near as original as possible. Why bother to put a binding on fretless board? That's not even a common thing to do anyway.
Post by: 66Atlas on January 15, 2014, 05:57:12 PM
I thought Badass came out in the mid 70s. Pickups kind of look like Schaller humbuckers to me. The cap on the neck heal seems kind of strange...if it really was an employee build why not have Gibson knobs, pots etc.???  Didn't Gibson sell off a bunch of leftover parts when they shuttered the Kalamazoo plant? Would make me wonder if someone bought up the body and then finished off with other parts especially since some of the bits seem more early 80s...
Post by: doombass on January 15, 2014, 07:21:06 PM
The neck heel (ebony?) extension would possibly strengthen Rob's top veneer theory. If a veneer was added to cover up holes, the neck would sit higher leaving a body edge on the back by the joint, then you'd need that extra piece for the heel to be lined flat to the body's rear surface.
Post by: Dave W on January 15, 2014, 08:53:09 PM
It's not a Gibson bass. A bass made with some Gibson parts isn't a Gibson even if it was made by an employee -- which I doubt it was.
Leo Quan (Badass) was founded in 1975. Dimarzio was founded in 1972 but the Model G wasn't around that early.
Post by: sniper on January 15, 2014, 09:58:31 PM
Quote from: Dave W on January 15, 2014, 08:53:09 PM
exactly ... I know a guy that has a none-Epiphone, Epiphone one off kind of thingy with a fake Starfire pup. HEHE
Post by: Grog on January 16, 2014, 05:44:45 AM
Quote from: 66Atlas on January 15, 2014, 05:57:12 PM
I had a contact for years, who's mother worked at the Kalamazoo plant. Many of the former workers must have had tons of spare parts at their homes, & he seemed to know who had what. He was able to locate just about anything I was looking for. He would then ask me to give him a price that I was willing to pay............always took my offer & sent the parts. Then one day he fell off of the map............
Post by: sniper on January 16, 2014, 07:59:38 AM
Quote from: Grog on January 16, 2014, 05:44:45 AM
Same, same. got a fingerboard and neck from a guy who was selling a bunch of stuff from a warehouse auction of old Gibby/Epi parts in Kali. Went on my first "parts bass" I gave to a kid. Yeah, that is an actual Starfire pup in there and not a Freddy H. pup.
This bass.
Post by: Granny Gremlin on January 16, 2014, 09:41:02 AM
I am doubtful about the veneer thing due to the binding.  The dude woulda had to have sanded down the top wood, and probably remove the binding, add the veneer and then rebind it.  Too much work when you could just plug holes and refin solid.
Look at this pic:
(http://i205.photobucket.com/albums/bb320/hexabuzz/IMG_0850.jpg)
There is no veneer stepping above the binding.  The pic of the open control cavity is too dark to see any layers in there from what I see.
I would believe the sellers story, but as Dave said, that doesn't make this a Gibson, and it certainly doesn't make it desirable at all (unless you like the result, but it's all kinda of characterless bits) or valuable.  I suspect they took a bound but otherwise unrouted (or just control route) and unfinished body and neck (without fretboard, or replaced it later) home and went to town. Looks like the structural work (fretboard, routing, even the finishing) at least was well done, but that's the only good thing I can say about it.
Post by: Basvarken on January 16, 2014, 11:45:16 AM
Good point Jake
Post by: drbassman on January 16, 2014, 12:43:30 PM
Quote from: sniper on January 15, 2014, 09:58:31 PM
Sounds like something I'd do in my Frankenstein workshop!   8)
Post by: chromium on January 16, 2014, 01:05:36 PM
Quote from: Granny Gremlin on January 16, 2014, 09:41:02 AM
Look at this pic:
I'd tend to believe that.  Recall all the unfinished neck blanks, headstock veneers, etc... that GreatDealz was selling on Ebay.  I'm sure plenty of stuff like that scurried out of the factory over the years.  This is probably someone's personal project based on those type of parts.
