I want to reduce the sharpness of the fret ends on my bass. I am not experienced in this procedure and would like some tips from the experts! (ie: what file to use, what angle to file, etc) Thanks in advance.
Me too. I have one bass where the frets stick out the ends of the fingerboard every winter.
I follow this guide............. http://www.stewmac.com/tradesecrets/promo/ts0013_fretends
+1 on Stew Mac's guide.
You can also use a regular fine file for the major work and 320 or 400 grit waterproof paper for the rounding over if you're careful (use it dry or just spit on it to keep it moist, not wet ;). Mask off between the frets and make sure you don't go through the tape.
I tend to prefer using an angle-grinder, but they don't allow them at the sanatorium... :o :o :o
I had to replace the edging when I replaced the binding on the T'bird and used a block along the edge to keep everything at a pleasing angle with something between 300 and 600 grit, with a needle-file for the edges...
Tom... that's weird... wait 'til winter then out with the file - blitz those frets... ;)
Robert... I wouldn't want to angle an edge to greatly - just enough to not be a problem for the edges of your fingers...
Great tips guys! Will attempt to put an end to sharp edges.
If you have a lot of fret ends to do you can make a beveling file like this (http://www.stewmac.com/shop/Tools/Files/Fret_Beveling_File.html?tab=Pictures#details) by gluing a fine file at the same angle as the fret ends. It helps keep everything at the same angle. But I wouldn't do it for just a couple of frets or if only a tiny amount of metal needs to be removed.
